This is by FAR the best tuning tool I have encountered to date especially @ $1100, after starting out with snap on chassis ears years ago for all my V8 carb jobiies.
I have been searching for the ultimate KNOCK detection device for years and a decent detector can sometimes mean the differrence between life and death of an engine especially if a 1/3rd party fault occurs during a tuning or power run. The only other knock monitors worth a pinch of salt is the HKS one but it requires extensive modding to be truly effective and useful and the knock-box but quite simply i have never really liked using it and the K-mon seems to be far more easy to use and better at detecting knock.
http://www.gizzmoelectronics.com/Kmon.htm
  • Replies 45
  paulr33 said:
yeah curious how much
the hks knock amp costs a bomb
i will post up pricing 2moro.. i cant remmeber :D i got this one on loan till the next batch is released. Im sure it was only 1100 or round abouts... half what everything else is.
  180bfj20det said:
Sounds interesting. How much does it cost and how does it compare to the link knockblock?
better for sure. It is by far the best thing for knock detection i have come accross.
Cant seem to to download instruction booklet etc.
Do you have an instruction booklet handy?
How easy is it to use?
What settings do you use on your engine and if you want to change to say a big block chev, could you use your instruction manual or is this trhough experience only?
This subject is of huge interest to me as I tune my own cars, but admit Im weak in detecting knock. Be nice to have a gizmo like this, but im sure there must be rule of thumbs that exist when coming to using these detectors, as youre knock and final tune is only as good as the setup (ie sensitivity, placement of sensor and the like).
Care to elaborate/educate us a bit more on them? I keen to learn.
PS i have tried using microphone on blocks etc....useless method (for me anyway).
Seb
I would imagine the frequncy of knock is totally different and with the bandpass frequncy definability of this product means that it could differentiate. But surely theres a limit, how do they tune dragsters?
Watching thread.
  unique1 said:
How much power are knock detection devices like this good for? ive been told with forged bottom end, big cams and solid valvetrain and 700hp+ (at wheels) that its very very hard to hear knock at all over the other engine noises, is this true?
Havn't used a snap on chassis ear but the steelman chassis ear works very well if you know what your listening for. I would be very dubious to use something that is not a direct amplifier of actual enigne noise - as in I prefer no damping of any type.
  • 1 month later...
1000% better than steelman chassis ears.... steelman and snap on are made by the same manufacturer are are crude and dont pick up half the knock compared to the K-mon... chassis ears are pretty back yard honestley thats why i upgraded. Best thing is the datalog software is handy and very good as a visual aid also.
Good enough for apexi to use it as their official tuning partner!!
http://www.apexi-usa.com/news_special.asp?id=12
  • 1 year later...
  Guilt-Toy said:
i invested in one of these, thanks for getting it to me sooo quickly Trent!! looks good ;)
nice work let us know how u get on i still havent got my head around setting it up, i dont know how to adjust the settings to detect knock but not detect other random noise like it seems to be doing, ive had it for over a year and never used it due to this, i got a big tune on monday and would like to set it up to make life easier when the tuner is tuning it. Ill go for a run tommorow and see what readings i get on current tune (560hp at wheels).
Edited by unique1
okay.. had to make some adaptors for the knock sensors as they are not a direct fit to the stock RB knock sensor position.
Made up 2 x brass plugs with the same thread as the stock knock sensors and then drilled them and tapped them then screwed them to the block and then screwed new knock sensors to them.
Had to take the starter motor off to get to the rear knock sensor. bit of a pain but what the heck.
On the dyno, i just dropped the screamer back on, got rid of the cat (for hill climb) first run on 20psi, 480rwhp on 20 PSI!!! i was listening to the run and not a sign of detonation, the knock sensors on the Gizzmo software did not read anymore then 40....
Impressed, the AFR was 13.3 on full boost! 12deg timing as well with 20psi - most power it ever made on 20psi.
So my whole excersize for the day was to get the least power i could for the hill climb, richened it up to 11.5's afr and took 1deg of timing out, did not want to heat the engine as 11 is pretty retarded.
Here is a screen shot from one of my runs, URAS is this okay ?? thats the typical run from my engine on 20psi with 450hp at rear wheels.
and for Unique1, here is a screenshot of my settings that i promised you! (i got 2 knock sensors, they come with one knock sensor standard)
This Gizzmo kmon ROCKS. my power fc knock sensors were reading spikes to 80 90 on full load, for NO reason, no mattter how much timing i would take out it was not changing, so i had to invest in one of these babys.
Retail price is around $1200.. if you see Trent he can do you one at a better price if you ask in a nice manner :banana:
I know its a big cost to outlay, but i am going to continue tuning my own car even though its got over 500hp now and i dont feel like building another engine.
Definatly worth the money!!!
Thanks again Trent! i got the item the next day after ordering, which is weird whenever i want something soo bad so quickly it normaly takes ages but this little baby came straight away!
Yeah i give this product a 9 out of 10, the only reason why it dont get 10 is cos you need to power it with USB only, and the price is pretty high (im a tight arse)
ohhh another thing that i did not like about the unit is that when you have your laptop plugged in and charging with a 12v to 240v inverter the unit gets lots of feedback and shows 20 - 30 knock at all times...
is there anyway around this ?
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
