Ok, I know this is not a very car issue, but hoping someone can help me here.
I've sorta recently moved to the suburb of Fisher and just got my phopne line connected.
Telstra told me that they could supply ADSL2 from the Weston Creek Exchange.
Now being as expensive as Bigpond is I've been trying to find another ADSL2 provider with not much luck at all.
(all said no, except for Exetel which said they don't have any ports left and need to wait for someone to cancel their account first)
so 2 questions,
1) anyone out in Weston Creek Exchange with ADSL2 and if so, who with?
2) if no ADSL2, who do you guys go with for normal ADSL?
Cheers
Michael
https://www.sau.com.au/forums/topic/176924-broadband-is-weston-creek-exchange/
Thanks, but already have and even did a search on 'Weston' and there wasn't much.
Also did a search on what providers were available for my number, but just want to see what people around the area think and have.
cheers
Try this.
http://www.adsl2exchanges.com.au/providere...hp?Location=ACT
http://www.adsl2exchanges.com.au/viewexcha...p?Exchange=WECK
To be honest, I'm an Internode man - despite the recent price rise. You get what you pay for, and with internode you get outstanding quality of service and quite possibly the best Call Centre system in the universe (you leave them a message and they call you back corresponding to your point in the queue).
Failing internode, probably westnet.
That said, in Canberra, I found that using TransACT 2mb/512 link via Velocity Internet was the best fit for me.
Edited by nsanity
'Node for the win man.
I'm in Bonython and there's no ADSL2 here either =(
Thanks guys for the info. Went with IInet transit plan in the end after ringing around with no luck with ADSL2.
just hope it all works.
Good luck with that.
iinet have been less than spectacular of late (like the last few years).
Damn, after all the efforts, I got rejected from over 8 ISPs. Looks like since I'm 4kms from the Weston Creek exchange no one can supply me with ADSL1 or ADSL2. pissing me off alittle since they all say they can supply it, but when they try to connect they can't.
I'll have to go for Cable either via Telstra or Transact. Even Optus doesn't supply Cable there.
Life is sucking alot at the moment, no Net, no GTR, no spare time, Grrrrrr.
Hope no one else out there has as much problem as me.
The house i just bought in Curtin is able to get ADSL 2 which makes me a very happy kid :thumbsup:
I have lost it multiple times at various ISP's over the fact that the suburb i am currently in is surrounded by suburbs which have ADSL 2+ but no not mine dslkjgsdjlkgfsld
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
    • How will O2 sensor voltages help to identify it when it is sputtering?
    • What do LTFTs look like? What do MAF voltages look like? O2 sensor voltages/AFRs? Knowing O2 voltages especially when it sputters would help a lot.
    • Isn't this what everyone immediately sees in their mind's eye when someone gives them a total width number and an offset?
    • It won't be this - not while it's driving, anyway.
