Fs; Bee R Rev Limiter
I'm not sure where you are, but United Terrey Hills has E85.
Do you mean not a limit to a certain power level? Surely if an injector is 100% open, there will be a limit to how much fuel can flow through it. -
Its a VR30DDTT, LPFP is Low pressure fuel tank (in pump) and HPFP is High pressure / mechanical fuel pump. Injector size doesn't seem to be a limit on that engine
So you want to run e30 on stock injectors and fuel pump?
