  • Replies 40
So... perhaps a heads up?
If this is correct... Series 2 R33 has the ignitor built into the ECU, so you probably can't use the RB20 ECU in a series 2, right?
The ignitors/transistors are not in the ecu at all, they are in the series II coils.
Series 1/2 ecu does not matter. Hence a single model PowerFC fitting both model engines series I and II.
Yeah, Turbo Tune's dyno is only a few months old now. Comparable to Graham West's dyno now :)
ah sweet, have they got some-one down there who knows how to use it now.... :)
^ so your saying that cause its running a remaped 20 computer and not a pfc then the result must be fudged
come off it 210 has been made by alot of 25's with the same sort of mods
its not like he's claiming 250
Did I call BS at all on his figure?
I just asked fot IT and AT and the other factors.
And as always, I couldn't give 2 shits about a dyno figure. They mean nothing. Driveability and the proper ability to make use of said power is the key.
Plus, the main thing is area under the curve.
so the rb20 ecu is better than the rb25 ecu because it can be remapped ? i have a rb25det ceffie with a safc2 atm . would i get a better result running a rb20det ecu and getting a remap?
kermit
I think anything remapped is better than a SAFC... Thats y u get better gains from a remap than a SAFC tune coz u cant really change too much on the SAFC just ur air fuel mixtures.
Liam
Wow, really impressive results!!
Keen to try out an RB20 ecu with remap myself...
One question, would an RB20 ecu run everything if put into an R33?
(Other than VCT that is?)
Also, can speed cut be eliminated with a retune? Rev limit changed? Etc etc?
Cheers ;)
Cheers :)
Yeah the ecu will do everything the same, speed cut and rev limits can be changed, ecu still has cold start and knock retarding etc.
Cheers for that, will definitely be looking into this at some stage :)
Nice figure.. :D
You plan to throw the slide highflow back on it?
The old saying.... There's no replacement for displacement. :ninja:
yes your nickname says it all :ninja:
as for the highflow i sold it with my rb20 package to fund the 25 conversion, I was going to get another one from Slide but it looks like he doesnt make them anymore..
for now stock will do, might look at garret offerings down the track.
