I just bought an auto window winder of E-bay for $20, and I want to install it. Anyone have any idea on where to get the wires from for the connections? I figured out which wires I do need for the install, but, I don't want to mount everything in the door, TOO BULKY!!! I won't have any problems installing the unit, cos all the wires are colour coded. It's just basically getting to the wires under the dash, or somewhere else.
Can anyone help me as to the location for the window wires?
Thanks for your help out there!!!
PLEASE GUYS. I'M SURE THERE IS SOMEONE OUT THERE WHO CAN HELP ME.
Edited by tdan
https://www.sau.com.au/forums/topic/176947-auto-window-winder/
  • 1 year later...
Hi again... I have figured out how to get to the wires and how to get them through the door and the a-pillar. I was just wondering if there is anyone out there who can give me advice on which wires off the door switch do I connect the module to? I have attempted to use a test light and multimeter to get voltage from which wire does which, but the tests have been inconclusive and giving me mixed signals.
So, if there is anyone who could give me the advice, or tell me how to do it, that would be very much appreciated.
Cheers heaps.
with fiddling - yes. depends on the roof and how it actually works. if I can automate a convertible silvia to fully close the roof and lock it self - a sunroof will be a walk in teh park. are you electronics minded?
drivers door for the up wires.
poke and prod for the correct wires. nissan change them to much.
Thanks for that. I decided to just bite the bullet, use a test light and a sewing pin and that gave me the best results.
If anyone else would like assistance with this, PM me and I will try to help you out as best I can.
Tell you the truth a convertable would be easier to automate than a sunroof as a sunroof has tilt and slide. There will need to be a signal given whether to close it by sliding, or just from the tilt. I was going to get this auto wind kit from ebay but i called a few places and they have quoted me an arm and a leg to get it put in place and even more to get the sunroof to work.
Only thing i got wired to close when i arm my car is the side mirrors which fold automatically.
nah most of them are transisitor based anyway. for me its a case of two delayed signals to close it fully. same idea to open it.
nissan drop tops are a pain to automate. too many lockouts to defeat to make the thing do as you want.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
