Hi ppls,
Looking for a 1995 Nissan Skyline GTS-t manual preferably silver but black or white are ok. Stock rims, aftermarket exhaust and filter would be preferred but not essential. Not looking for anything extremely modified.
Can anyone help me out or know of anyone selling skylines or importer.
Looking to pay around 20k or less. These cars are imported for around 17k
Thanks
https://www.sau.com.au/forums/topic/17695-wanted/
