I get asked quite often how to tell if second hand shocks are OK. While it is not 100% perfect, you can do some easy checks, if any of these show a problem then its rebuild time.
1. The first job is to check for oil leaks around the top seals, on the shock body where the shaft goes through. Any oil (even a tiny bit) is bad news.
2. Next make sure that the shocks have equal gas pressure, take the springs off and compare the front pair with each other. Push them down equally and make sure that it takes the same amount of force to push them down. Any difference (even a tiny bit) is bad news.
3. Then make sure that they come up together at the same speed. Any difference (even a tiny bit) is bad news.
4. Do the same for the rear pair.
5. Lastly look at the shock shafts, if they are not perfectly shiny, the same all the length and all the way around, then that is real bad news. They must have no rust, no scratches and no visible wear marks. New shafts cost more than whole shocks.
That's about it, if the shocks pass those tests then chances are they are OK, for now.
:D cheers :)
https://www.sau.com.au/forums/topic/176989-used-coilovers/#findComment-3234884
I did all the above steps stated when i bought some used coilovers a while ago but turned out that the pillow ball mounts were all worn out and knocking it's head off.
What i feel is that, you have no way to tell whether used coilovers are good or not until you actually fix them onto your car and drive them.
https://www.sau.com.au/forums/topic/176989-used-coilovers/#findComment-3235183
I wrote the above in the ShockAbsorber 101 thread in answer to a question on how to tell if used SHOCKS are OK, the additional test for strut tops are;
1. If they have spherical bearings then there is a 99% chance that the bearings are stuffed, so check them carefully.
2. Remove the strut tops from the shock/spring unit and rotate the spherical bearing, check for scuff marks and wear through the hardening. This shows up as discolouration and sometimes even surface rust.
3. Bolt the strut tops back on the shaft shaft (without the spring), then check for play by rocking the strut top while holding the shock solidly (in a vice is best).
4. Any free play, visible wear or knocking means that the spherical bearings are stuffed, this usually means buying new strut tops as most Jap coil over kits use unique sizes of sphericals.
If the guy selling them won't let you do the above tests (plus the shock testing) then WALK AWAY, they are most likely useless.
;) cheers :D
https://www.sau.com.au/forums/topic/176989-used-coilovers/#findComment-3236228
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
