does anyone know what these buggers are actually doing to steal them?
do they unlock the doors eg - with thick steel wire to hit the passenger door unlock button on the drivers door main switch panel? -thats one of those things you'd be stupid not to disconnect. but then again if they try long and hard enough, they could probably even unlock the drivers door lock itself.
and what do they do to start them up? it is just like hotwiring any car?
one would think immobilizers actually do something...!
this is fking madness! i would love to catch one of these c*nts!
yeah dude...my silvia got stolen once from my garage..f*k dude...if i had a gun id shoot this mfkrs..im serious..the way they took my car was by f*kn up the key barrell..they took out the plastic bit at the end and then vala..thats all..u just need a screw driver to start, and the other thing my alarm wasnt on...so it was more easier...but the car was found in 3 weeks...stereo stolen ignition damaged.
  • Replies 69
is there such product that locks the key/ignition barrell? a plate or something you put over the key slot?
for commodores years ago there was such a thing as a full metal jacket but as i say this was for butterfly ignition commodores
http://www.calaisturbo.com.au/showthread.php?t=26572
http://www.raa.net/page.asp?TerID=363
nope, a loop of the blue packing tape stuf (used to hold things to pallets etc) -
Basically, I was amazed how easy it was with absolutely NO sign of damage what's soever..... scary really :S
Note: don't want to detail how it was done, people don't always need to know every detail.
Edited by Hotwire
fact is if they want your car that badly. it's theirs. i liked the idea of removeable steering wheels. cool and very effective hah. but another alternative is to get a direct kill switch to your fuel pump. just hide the switch under your seat or something. good luck trying to start the car without fuel!!!! they can twiddle with wires in the dash for as long as they want ;)
thats exactly what ive done. cept not under the seat! :D
Not jumping to conclusions but last night I parked behind a white S2 33 type M with stock wheels and CC plates. They came from out of the house it was parked in front, looked at me suspiciously (I was in my 33 and expected some 33 mutual respect) and drove off. The only other thing I can remember about it was it's exhaust. Do you know what kind of exhaust is on it, Ryan?
Yeah sounds about right. They guy drove off nicely, like it's not as if he was driving it like he stole it but if you like I can find out the street address etc of where it was and PM it to you and you can go from there. I saw it in Belair (near Blackwood)
I just messaged my mate who lives on the street. He should know what number the house is. He also saw it with me and made the comment that that guy (who is the boy friend of some girl at the address) has had a few different import cars.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
