  • Replies 69
Yeah sounds about right. They guy drove off nicely, like it's not as if he was driving it like he stole it but if you like I can find out the street address etc of where it was and PM it to you and you can go from there. I saw it in Belair (near Blackwood)
hey i drive mine like that all the time don't assume cause someone drives hard it might be stolen
A simple yet highly effective way to slow potential thieves down is to modify the ECU bracket (holds ECU in behind kick-panel) so that the ECU can be removed and refitted as required.
With this kind of set-up in place it's a 1 minute job to R&R the ECU. Kind of hard to start the car without the ECU fitted. Of course, thieves can simple bring their own ECU along, but hey, at least it adds to the time they need to successfully steal your pride and joy.
Black32; i wasnt suggesting that people post up "instructions" on how to flog our cars -
look at it as a request re peoples experiences with theft, and ways to deter the theiving little c**ts. theres nothing wrong with little tips and tricks to make life harder for the average bandit.
some good ideas mentioned guys! :ninja:
Edited by MSPEC33
As a person with full comp insurance and paying 1,700 a year for it, I would still like to know how they steal our cars and how we can make life harder for them, putting up information on this will also make sure skyline owners do things to prevent it from happening.
Do you think everyone feels happy when their car is stolen compared to when they find scratch marks on their door because the theif couldnt break in?
Prevention is better than cure.
I tell ya what, I've always said this, BUT if my car was to get stolen, I would much prefer to see it burnt to the ground, as your car is NEVER the same when and if returned, Is too much of a headache to fix it back to what it would have been, It's more anoying to have your car broken into for a couple of CDs and smokes, cos it's not worth claiming anything and is generally cheaper to fix the smashed window than pay excess!
If u cant afford full comp insurance, then dont drive a nice car, or hit mine for that matter.
Damn straight.....
x3 thats the first thing people should allow for when purchasing a vehicle of any kind
couldnt agree more @ burnt to the ground, my first skyline i had was aussie R31 i bought it cheap from a guy cuase it had been stolen and the motor had been cooked he replaced the bottom end but he said it didnt drive the same when i got it and stopped the front end would bounce due to stuffed shock i replaced those and car was all good :D
had it been my car when it was stolen i would of gotton rid of it also
its the unfortunate truth guys,a nd you know it. not every person with whatever car has full comp insurance. especially a lot of the much younger drivers. i may be incorrect in some peoples eyes, but 1 in 3 turbo skylines that i see on the road today are driven by young drivers. The facts are young drivers = an expensive insurance bill when it comes to these cars...
hell - i suffered when i bought my car in 2001. around $3600 per year... i pay almost a quater of that now, so i'd be an imbesile not to have full comp.
Hmmm... yeah but Daz, the insurance payout is never going to cover the massive loss (time, effort and money) that I would suffer if I lost my pride and joy to thieves... and I've got agreed value of $38k ('94 GTS25t)
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
