http://www.oroadsports.com/phpBB2/viewtopic.php?t=16950
From another forum I'm on.
The following link is the Regulatory Impact Statement (RIS) that DECC have issued to assist with the introduction of the proposed laws.
www.environment.nsw.gov.au/resources/07186noiseris.pdf
The following is my rough outline and by no means a complete overview of the proposed laws that DECC will be presenting to the government.
Clause. 18
"Noise control equipment to be properly maintained"
A person must not cause or permit a motor vehicle to be used on a road or road related area if:
The motor vehicle's noise control equipment allows the emission of more noise than the original noise control equipment fitted by the vehicle manufacturer, or
if an authorised officer (police etc) reasonably believes the equipment has been modified in a way that makes it less effective than it would have been if the modification had not been made, or
the motor vehicle's noise control equipment is not securely in place, or
a temporary noise reduction device is fitted to the vehicle (like a removable baffle, even if it is fitted and the vehicle is compliant to it's noise requirements) or
if the equipment allows gas to escape from a place other than the intended exhaust outlet.
And
A person must not:
Remove, or
render less effective, a motor vehicle's noise control equipment, otherwise than for the purpose of repairing or replacing it, or
replace a motor vehicle's noise control equipment with noise control equipment that is less effective than the original noise control equipment fitted by the vehicle manufacturer.
Fine: $200 *
* Penalty levels
The maximum penalties provided under the Noise Control Regulation for a "Court prosecution" are currently $16,500 for individuals and $33,000 for corporations.
DECC said of Clause 18; The aim of clause 18 is to provide a means of detecting noisy vehicles that avoids the cost and time associated with noise testing where it is not strictly needed. Noise testing is often not required to identify the fact that a motor vehicle's noise control equipment is defective, and a simple visual test and aural check is all that is needed. However, in cases where noise control equipment is modified and the officer is unsure whether the noise control equipment is less effective, a noise test should be carried out. Noise tests are often carried out by DECC authorised officers to support the finding of defective noise control equipment. In practice, a Police Officer's ability to carry out noise testing is limited by the cost of the equipment, lack of trained personnel, and competing priorities.
Use of informed subjective (guessing!) assessment to decide a noise offence is central to NSW noise legislation. The concept of offensive noise underpins the legislation. Powers under the POEO Act and existing Noise Control Regulation enable officers to exercise judgement in deciding whether noise is an issue.
DECC urges stakeholders to provide feedback on the new Regulation.
Comments, marked 'Noise Regulation Review', must be received at the address below by Friday 13 July 2007:
Noise Policy Section Department of Environment and Climate Change NSW PO Box
A290 Sydney South NSW 1232 Phone: (02) 9995 5996 Fax: (02) 9995 5935
or via e-mail at [email protected]
Read the full RIS it's probably going to impact you! If you have any comments on these proposed laws or the RIS then please send your comments to Chris Turner, Chairman of the NOISE committee, MCCofNSW.
Regards,
Chris Turner
Mob: 0427-200-310
Email: [email protected]
https://www.sau.com.au/forums/topic/176997-new-noise-restrictions-coming/
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
