this forum could b a good place 2 exchange ideas about modifying our skylines.
What do you plan 2 do with your skyline?
with the Akira mobile, suspension will B the first thing 2 do. I've got JIC coilovers, and a whiteline handling pack going in next week.
A NISMO 3.9 diff centre will b next. Following that the fuel delivery system ......I could go on and on, but thats all I can afford this year.
https://www.sau.com.au/forums/topic/177-building-up-ur-skyline/
  • Replies 42
Hey y'all.
I currently have approx 170rwkw on 12psi (i DID have 165rwkw at last dyno on 12psi and have done stuff since then.)
My next improvements which will be implemented within the next month are:
[list:7c52f7e0ba]
[*:7c52f7e0ba]New 6 Puck Clutch (mine is sceeee-roooode!)
[*:7c52f7e0ba]S-AFC
[*:7c52f7e0ba]Fuel Cut defender (which I already have, I just need to fit it - I keep bouncing off fuel cut when running 12psi).
[*:7c52f7e0ba]a cat! :) (no more flames for NOZILR!)
[*:7c52f7e0ba]cold air induction + partition.
[/list:u:7c52f7e0ba]
Then later down the track i will high flow the turbo and look at lowering the back of the car more... maybe even a kit.
I plan to hit 200rwkw this year and i'll leave her there.
Akira why a 3.9 diff why you can hit 270 kph @7000 rpm isn't that enough
how do I know I know someone who has?
my plan
well I was going to leave my car as it was till the drama's gearbox turbo etc so now I have upped my power target.
200 rwkw on stock injectors.
I doubt this is possible but JMS and that donnan bloke reckon you can.
So we will see to do that I will need a biger fuel pump. and I'm praying my afm will be ok as I sold my z32 one it should be. and an adjustabel fuel pressure regulator.
as for clutch I had heaps of options I could have got merli's race clutch but I decided on an organic heavy duty daikin. tip of the day get a price from http://www.discpads.com you have to email for a quote but they are very cheap. I have 225 rear tyres atm but I'm concidering getting 8 " wide rims and going 245 X 45 X 16 as I have found tyres this size but not for a while. I would like to run a low 13 second 1/4 mile and think I might have the package to do it.
my car doesn't need much else.
meggala
Hmmm, where do I start.....
Finish off and seal up the cold air partition that I made. PRANK let me know if you want any pics, I can send the template to you.
3 inch dump pipe and front pipe to cat.
Fix the crapy bend that a exhaust shop put in (not really important but it's bugging me).
Get a front mount on.
New FM901's on the back cause the ones I have at the moment don't do much.
Get the front spoiler fixed/repainted where I nudged a gutter !!!
Adjustable fuel reg once the front mounts on to bring down the A/F ratios.
Ummmm, that's all for now.
J
well tomorrow the new timing belt goes on.
Then can put the SAFC on and advance the timing some.
next will be a suspension upgrade, i'm impressed with onaruns information about his and the info on the whiteline site. then it will be a dump pipe, front mount and an AVCR and that should do me for a while.
My turn! - As far as im concerned the car is stock but hey!
3 inch HKS Hyper Cat Back Zorst
HKS Air Filter
Standard Boost ( fighting the temptation )
King super low springs
Rear GTR strut brace
Whiteline front strut brace
Coming in the next months
New Wheels
New Bonnet (woohoo carbon baby)
GT Wing
Front Mount refrigeration system
Glad 2 know I'm not the only one with S.I.S ( Skyline Improvement Syndrome).
Whileline asked me how I want the car suspension set up, and I replied "like schumachers ferrari" Might have 2 wear a kidney belt on the next Akuna run :)
Meggala,
Thanks again for Ur advice Re; suspension and diff set up earlier. I,ve currently running a 4.3 diff ATM. My mate who imports modified cars, has 2 diffs with my name on it the nismo 3.9 and 4.1, along with enough parts 2 keep me poor for the next 3 years. Another mate told me to try the 3.9 as it should have faster hook up, greater strength and far less wheelspin and negligible disadvantage at take off due to power of engine. He worked at Diff Technics and knows his stuff. the 4.1 diff will go in if I find the other diff unsuitable.
My car does 201rkw ATM on standard fuel delivery system, with fuel starvation issues at high RPM 7000+ ( found this out at Eastern creek)
With upgraded fuel delivery system, Ur car could easily crack the 200rwkw mark. I am aiming for a max of 1.4 bar and will be happy 2 leave it at that. I think my car is tuned conservatively ATM and am happy 2 leave it that way ( dont want 2 risk damage to motor for more power)
Anyway guys, its been good 2 exchange ideas ( I've learned a lot here)
Good luck with your project skylines :)
Onarun,
I got my JIC coilovers second hand at mates rates, along with a Tomei Triangular front strut brace and the diff. The car it came out of from Japan had travelled 28K and the parts look new.
BTW the coilovers are FLT-a2 height and damper adj i think.
What set up do U have in Ur car?
akira- dude, you asked
[b:e41034a8a7]Suspension[/b:e41034a8a7]
[u:e41034a8a7]Full Whiteline suspension package[/u:e41034a8a7]
No specs on suspension as I had an accident and it needs a re-tune. :cry:
Front radius rod bushes
Front adjustable stabiliser bar
Front strut brace
Front camber kit allowing (+1 to -2deg)
Bilstein monotube shocks
Lowered and higher spring rate
Rear sub frame support bushes
Rear adjustable stabiliser bar
Rear camber kit allowing (+1 to -2deg)
Running 17x9 inch AMG's with Dunlop FM901 235/45x17 all round
HICAS system disabled :wink:
[b:e41034a8a7]Engine[/b:e41034a8a7]
K&N air filter & air duct
Air filter and radiator partitioned
Blitz DSBC electronic boost controller
Free flowing 3" mandrel bent exhaust from turbo back
HKS front mount intercooler 600x300x100 :twisted:
Oil catch can
High flow fuel pump
Heavy duty clutch and clutch plate
HKS oil cooler
Apexi Power FC ECU computer
[b:e41034a8a7]Other[/b:e41034a8a7]
Running 12 psi
Bonnet vent
Endless NA-S brake pads
Air ducts to brake pads
Castrol SRF brake fluid
4 point race harness
Fire extinguisher
Blitz turbo timer
Plates ONARUN :)
Special thanks to Paul G who transformed this car into a machine
BD4's for the time, effort and skill spent.
Whiteline for the truly amazing suspension
The above is straight out of my web site. Sorry for the length.
Coming up I have a turbo upgrade. Haven't decided whether I'm hi-flowing yet or going all out. I think I'll wait and get a HKS 3040 or something and do the injectors, manifold, head gasket, adj cam gear (exhaust) and pulley.
your car sounds nice onarun go the proper big turbo just wait its worth it.
[b:3a3d9a00fa]So should I put an rb25det in my car![/b:3a3d9a00fa][/color:3a3d9a00fa]
I'm serious Its not the turbo a valve has gone and a ring is worn :-(
f**k
it ether that or a rebuild casue the theifs want 1500 for an rb20 now with out ex-manifold or may be I'll put an sr in .
I'm about to scream.
[b:3a3d9a00fa]shit[/b:3a3d9a00fa] [/color:3a3d9a00fa] [/size:3a3d9a00fa]
I've really had it atm. and we only have one car cause someone is using our second car.
meggala :)
    • Good timing mate, welcome to God's country just in time for winter Seriously though....how cheap is rural/regional.
    • Thanks guys! Some pics attached 馃構
    • Big enough for you, Jackie, and some puppers mate! I vote some GSDs, but I am biased   How big of a block is it on?
    • Well, fun day was had, I finally found a house that will do me just fine, 1980's brick build, but with full fresh renovations, plus new colour bond fencing all round so puppies are incoming 馃悤, and water tanks for the garden, and it's located in West Goulburn..... @Duncan 馃, so day trips to Wakie to watch cars going Zoom will be on the cards In the end it cost well under my budget and was actually better than alot of the more expensive joints I was looking at, it is in a good area, close enough to the shops, public transport, and the Wollondilly River Weir,  and the great walking paths along the river, but far enough away from town to see minimal traffic The deposit is dropped, the conveyancer is conveyancing and I should get the keys in a week or 2 as the property is currently unoccupied  As with everything I own, I'm doing up a modifications list, as it doesn't have solar, that is first up on the big list, all of the panels and enough batteries to keep the joint warm, or cool, followed by a largish carport out the front, the small list, which will start as soon as I have keys, is some security stuff, like cameras, screens, and the usual "crazy prepper" additions that weird old people like (mouse holes to stick shot guns out of, and the usual man traps that the average person installs for the unsuspecting and unwanted guests 馃ぃ) The gardens front and back are OK, but, not to my standards or liking, so landscaping will be a fun job to start getting into, so when spring is sprung I'll do a heap of planting, lots of natives and vegetables is the plan, the old owners were more "Old English Garden" type, so basically Roses and other weird looking things that are destined for the green waste bin One thing that is staying garden wise is a nice established hedge out the front, it is about 5 foot tall and covers the whole front of the property from prying eyes As for the car hoist, the roof in the garage has some height to it, but, I'll need to get an installer out to see what can be done, width wise may be a issue, but my building inspector will be getting back to me over the next week with his recommendations  Small, but cosy
