Hey all,
I've got a 1990 R32 Gtst with 217rwkw and an NPC brass button clutch. I had some trouble a while ago with the clutch not disengaging properly i.e. when pulling up to a set of traffic lights with my foot on the clutch and brake pedal, the car would lurch forward slightly and want to "drive on." I would then have to reef the gear stick out of first gear and in to neutral, and then back into first and then it would be ok untill I had to pull up at another set of lights etc. Initially I put this down to the heavy pressure plate in the car, however i took the car back to my workshop and had them change the pressure plate to a lighter one. The car was then alot more driveable on the street and the problem seemed to go away, until a couple of days ago and it has gradually gotten worse. I can't come to a stand with my foot on the clutch without having to reef it out of gear when I stop. I have changed both the Master cylinder and slave cylinders a few months ago and the clutch system doesn't appear to be losing any fluid, I have bled the system correctly and now I am at a loss. I was wondering whether anyone else has come across anything similar and any help would be greatly appreciated.
Cheers Dylan
https://www.sau.com.au/forums/topic/177013-r32-clutch-troubles/
You may need to pull the peddle box out and check to see it hasnt broken any spot welds on it, could be possible that the box is now flexing when you put your foot on the clutch and not acctually pushing the clutch in far enough.
Other issue may be master or slave, i know you said you replaced them but were the replacements brand new? If not then whats to say there isnt a problem there.
Finally, in the middle section between the master and slave theres the box with lines going in and out of it and a bleed nipple..piss this section off all together and just run a line from the master to the slave, then bleed starting from the master followed by the slave.
Did you machine the flywheel when changing the clutch?
My guess is the flywheel is worn into a funnel shape (only very slightly, probably invisable to the eye). So when you shove the pedal in the clutch plate is still grabbing along the outside edge..
If the flywheel is fine, perhaps there is a physical defect in the pressure plate. Or maybe you have a mismatched clutch bearing (happened to me, I was supplied a bearing slightly shorter than what was required, and the outside clips on the bearing were hitting the solid edge of the pressure plate).
Hope that helps. Clutches can be a real pain. :blink:
I had a similar problem to this once and it was the slave cylinder was bleeding back, seals were on there way out, the more it got used the worse it was but recovered when driven for a while and clutch not used had me buggered for months till I found it ,just wouldnt travel full length same can happen to mastercylinder ...
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
    • Your profile doesn't say where you are, but you can get your current turbo rebuilt by any competent turbo shop, places like Precision Turbos or GCG They can replace the core with a modern ball bearing unit and should be able to source same or slightly larger wheels to fit in you housing. Note if you change the core you may need new oil and water lines too
