Howdy Lads,
Got these parts up for sale due to selling my car.
Power FC
I got myself here a Power FC for a R33 series one engine without hand controller, i searched for months for one of these and imported it from Japan.
Price : $950 (can post anywhere needed)
Garret T04 Hi-Flowed And Rebuilt New Condition (never been used since rebuild)
0.63 rear housing
0.58 front housing
Rated 600hp
Two internal wastegates / hi / low spring
Optimum boost range 19-22psi
Full boost should be 3000-3400rpm on RB25
** Will put up pictures of turbo tonight **
Price : $800 (can post anywhere needed)
- Luke
https://www.sau.com.au/forums/topic/177017-power-fc-r33-gtst-garret-t04-600hp/
Hello,
Im located on the Gold Coast in QLD but can do postage at buyers expense.
Im unsure how it would compare all i know is for the size of this turbo its will be on boost fairly quick due to it being high flowed and it offers great HP potential. And ofcourse its Brand new condtion. Not a single km on it. Would be very easy to pull big HP if you have the correct gear with this turbo.
Bolt straights up to RB20 or RB25.
- Luke
Edited by RB20DET_Silvia
do you have any photos and receipts for the turbo?
what would be the expected rwkw figure you could get with this turbo on the right setup (r33 with power fc and all supporting mods)? what other mods will have to be done for it to fit? will it go straight on the manifold and oil/water lines etc?
btw im interested in both items
I would like to say its a t04e i believe it is.....but im unsure.
With this turbo and Power FC along with injectors or hi-flowed standard injectors, fuel pump, fuel reg and a tune you could easily pull over 400 to 450hp (300-340rwkw) at wheels, a aftermarket headgasket would also be a good mod to do if you wanted to run high hp all the time. If you wanted to go over 500hp you would need to do more engine work to run that HP everyday on your engine.
The turbo will straight bolt on to all your standard lines and manifold etc....
I found a picture of the turbo on my computer.
- Luke
wanna swap the power fc for some wheels ??? swap ya this weekend :) - everybody needs a spare set of wheels
http://www.skylinesaustralia.com/forums/in...p;#entry3233590
howdy, im interested in the turbo... u stated it had not seen any use since being rebuilt/high flowed and was done recently, I'm asking the same question someone else just did, do you have the reciept for this? cheers Damo
Hello im on the gold coast,
And i pm'd u all....and sorry wheels i do not need PFC is for sale for cash!
- Luke
You'll regret this...!!
haha nah, free bump for someone selling an rb25 pfc for a fair price!
regards to ur turbo.. is it suited to a t3 or t4 flange ?? also is it internal or external wastegate??
cheers chris
bro if u scroll up it says that the turbo fits an rb25 manifold( which is t3) and in the 1st post it says its internaly gated, plus if you look at the pic, u can clearly see the wastgate actuator, which suggests its.................internally gated lol
yea sorry guys alot of posts here.. prob didnt read through an yeh didnt click on the rb25.. my bad.. thanks anyway
i hav an external gate anywayz and if i get the turbs can just weld up the internal one
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
