Hi guys, the purpose of this thread is not to tell people to never go there again, just put a bit more research in before taking an expensive part to him...
I recently bought a GCG highflow that was in need of the rear seal being done. I took the turbo there and dropped it off with his lackies (he wasn't there) and then asked them to give me a ring with the price before they did it. The next morning I got a call saying it was done and I owed $400. I wasn't too fussed about this because I wanted it done in a hurry, but the phone call with the price would've been nice. He also said it had another 2-3years life left in it which made me feel a bit better about it.
Anyway, then I put the turbo on and get it dyno tuned, then took it to Mallala and it seized after 4laps. :domokun: On the dyno it was clearly blowing lots of smoke and on the drive to Mallala, my mates told me it was blowing lots of smoke. I didn't think much of it because I thought it was my engine and I know my engine's not healthy. Also when the turbo came off, there was a HUGE amount of blowby, so much so that it filled my boost controller solenoid, all piping and there was a puddle in the compressor housing...
I took it back to him, he pulled it apart and said it was oil starvation, then did an oil flow test on my car and it was only getting 0.9L/min and they apparently should be getting 1.5L/min. So while there, we modified the banjo bolts (drilled out the restrictors) to flow 1.5L/min. I thought this was a bit odd as the turbo is supposed to be used with standard lines, and hence restrictors in place, so I rang up GCG and asked how much oil the highflows are supposed to get, and what did they say? 0.9L/min!
So now my car's feeding far too much oil to the turbo (in the range for bush bearing turbos) and is puffing smoke. So I need to find a couple of standard banjos to return it to normal.
I think it's also worth noting that before this incident, I had done about 2 years worth of track driving with the stock RB25 turbo and stock lines with NO oil related turbo problems. ;)
Anyway, all I can say is dont believe all the hype about Bill (like I did). I also went to MTQ later about it and they were VERY helpful, no money paid, gave me some advice, got a technical guy to look at the turbo and gave me a quick quote on a rebuild, unlike Bill who just wanted to sell me a brand new turbo... :domokun:
https://www.sau.com.au/forums/topic/177049-ats/
Yeh likewise Paully, Although I havn't actually dealt with Bill for a long time, the Hi Flow in my car is a ATS job, which was done a good 5-6 years ago when the car wasn't in my hands, and still holding strong!
Think it's almost luck of the draw, I know for a fact Shaun at Boostworx uses Bill, and he actually has done work on our race car also, and thats on a 3SGTE out of a MR2 which is now in a RWD car, and we all know they have issues with oil feed!
https://www.sau.com.au/forums/topic/177049-ats/#findComment-3235716
salad, fact of the matter is all reputable places and people have had problems with customers, even shaun I spoke to him after my turbo blew and got some advice out of him, he said to me its just luck of the draw and sometimes you get people that get soemthing done, walk out of somewhere and somehting stuffs up and run back saying it was their fault. I'd talk to Bill and tell him what you have discovered and what he plans to do and if you need to bring someone with you that knows more than basic. I doubt it'll have any affect though because Bill has been working with turbos since the 70's and has done numerous top jobs but im sure like any other place, he has done sub-standard work too. No one is 100 percent perfect.
Get Bill to ring up GCG about your turbo so he can hear from them himself and perhaps realise what he has done wrong if you are indeed 100 percent certain you are correct.
https://www.sau.com.au/forums/topic/177049-ats/#findComment-3235721
Its a GT30R Compressor wheel in a Rb25DET turbo shell since my turbo when it blew, it indeed blew the f**k up!.
I pulled away from you, pitty I was still running 6psi.
pitty i was running 5 to 7 max (stock.) and u stepped on it first :)
Wonder if i had full zorst and FMIC and 6psi constant... :)
Lol anyway u did pull away by half a car lenght, ill stop being a smart ass.
https://www.sau.com.au/forums/topic/177049-ats/#findComment-3235820
make an official complaint to the consumer authorities. dont hold back, you have rights mate.
you got screwed over 2 ways:
a) asked for a price first, but work was done without your consent and money was demanded (a big no-no),
and b) substandard workmanship, obviously by the lackies.
ATS is recommended by GrahamWestWorkshops as well, so most ppl are happy with their products and services.
but in this instance the stars obviously wernt aligned for you, and its cost you time & money when it shouldnt be like that.
Id recommend Sliding Performance (slide on sau) for a rebuild to the turbo. hes a great bloke, tell him the facts and Im sure he'll give you his best price. slide highflow FTWiinnnnaaaaahh!
https://www.sau.com.au/forums/topic/177049-ats/#findComment-3235895
Yeah, the point of this thread wasn't to say dont go to him full stop, but do a bit more research before hand as before this, I had only ever heard good things about him. After it happened, I found out about a few more people that weren't too happy with his work
https://www.sau.com.au/forums/topic/177049-ats/#findComment-3236746
pitty i was running 5 to 7 max (stock.) and u stepped on it first :D
Wonder if i had full zorst and FMIC and 6psi constant... :D
If you have a think about whats going on with a bigger turbo, its not as easy as saying "same boost and mine was faster".
The stock turbo is noticeably more responsive than a GT30. The GT30 also needs more boost than the stock turbo to hit its peak efficiency.
Its not comparing apples to apples. With the right mods a skyline with a GT30 will easily beat a stock skyline, but will have slightly more lag.
The GT30 really needs like 14+ psi to hit peak efficiency. I have the same turbo setup (from ATS) and even at 12psi it definitely wants to boost higher. :D
https://www.sau.com.au/forums/topic/177049-ats/#findComment-3238562
Agreed.
A mate of mine used to run a Gt35r at 8psi. It made 182rwkw. He pushed in another 8psi and picked up almost 100rwkw. :D
Once it got up over 10psi it started to net large gains in power per pound of boost; that was until the ext. wastegate started to tail boost off at high rev's. Which is why you don't run a soft 8psi spring and try to push double the amount of boost through it.
Such a pitty he never got that car sorted before selling it. :)
https://www.sau.com.au/forums/topic/177049-ats/#findComment-3239085
The GT30 really needs like 14+ psi to hit peak efficiency. I have the same turbo setup (from ATS) and even at 12psi it definitely wants to boost higher. :banana:
Notice the "ill stop being a smart ass" at the end of my post lol ?
I agree with, i was just messin with paully...doesnt take much to get him started lol.
https://www.sau.com.au/forums/topic/177049-ats/#findComment-3241628
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
