Hey everyone,
I did an engine, gearbox and diff oil change today on my R33 gtst, and took it out for a spin tonight. It was running really nicely, but when i took it above about 4500 RPM in mainly second it would hesitate, as if it was hitting a rev limiter or something.
It lost power but continued revving, but would miss - sounded like a braaaap! noise.
As a bit of background, all i have is a turbo back exhaust and air filter. Last dyno it was running peak boost of about 10.5PSI.
Its just a bit worrying and would like to get it sorted ASAP in case i am doing damage :D
https://www.sau.com.au/forums/topic/17705-help-missing-above-4000rpm/
First I would pull the plugs out and check them for hairline cracks in the ceramic. Then Check their gaps.
Slap them back in and if you still have a miss either you have a dud coil or there is a hairline fracture in the plugs that you missed.
I had a similiar problem where it would drive nicely then at around 4000rpm+ it would start to pull then braaappppp brap brapp then if I held it down it would kind of smooth out and start pulling again. Generally once over 6000rpm to 7000rpm would be ok.. It turned out a hairline fracture in the spark plug. I had cracked it when slapping in No. 5 cyclinder spark plug as I tried to use a swivel and not remove the engine pipe across the engine.. SO if you do spark plugs don't do it the easy way and use a swivel remove the engine pipe so you have 180degree access to the spark plug. Otherwise you risk cracking the ceramic.
I had the plugs in and out around 4-5times before I found the problem.
I think meggala's www site has a bit of info regarding using a multimeter to check them
Also check the springs that contact with the top of the sparky. If they are burnt or black chances are they are rooted. You can patch this up sometimes by removing that spring and using one from a pen. So i've read.. Don't know if it works or not though.
I would be very very wary of doing that.. Have you ever been booted by an electronic ignition? I have it doesn't feel very nice.
I couldn't believe the boot it gave me actually. I've been booted by mains before and it was very close to that i can tell you.
  • 3 weeks later...
hey guys i have the same issue (96 s2) put a boost controoler on it boosted to 0.7 bar to be safe and car felt like crap..really jerky..winded boost back down and the problem kinda went.. but a mate/mechanic looked at it and said coils or fuel is too lean... gets checked out on wed hopefully not too much of a drama..am concerned.. should I b?
It happens b/c the mixture gets way too rich, when you are running higher than stock boost.
Changing the plugs can help reduce the problem, but it wont fully go away until you sort your mixtures out!
I recently got my SAFC dyno tuned, and at around that point, I had my mixtures adjusted by -21%!!!!!! So as you can see, it was running MEGA rich there!!!! Now there is absolutely NO hesitation/misfire/spluttering at that point, just smooh driving all the way up to redline!
Th only plugs that helped me before my SAFC tune were NGK coppers: BCPR5E gapped at 0.7 ~ 0.8 mm, but like I said, it wont cure the prolem. If you go any colder than a heat range of 5 (>5) then you will see no improvement.
Just passing on what I have learnt from personal experience!
Zahos
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
    • These things happen And I believe "we, the people, who modify stuff, and actually use it, cannot have nice things" It's just a shame that it happened so soon after paint  I still win the award for quickly destroying newly painted panels I think, as my car came back from the paint shop all nice and shiny, until about 4 hours later when the boot was destroyed by a wayward locker that was blown around by the wind.... What doesn't kill you makes you stronger, and poorer.....dooh
    • This. And also, the rotor thickness is constrained by the calipers. Cannot be much thicker, if at all. Cannot be much thinner, if at all. New rotors are....fairly cheap. Turbo calipers can still be picked up for sensible money. Arguably, the best thing is to get R32 calipers and put them on mount spacers on 324mm discs. That's about the cheapest and easiest way to get quite large brakes that are essentially bolt on. And that's despite maintaining for years that the R32 calipers are not the best choice because they seem to be more flexy and creaky than the others. If you were prepared to put up with nasty little NA sliding calipers, these will still seem like Brembos by comparison.
    • A quick Google said 297mm..
    • Why would you not fit the biggest possible brakes?
