after installing a FMIC & big exhaust my car was blah! blah! blah! @over 3/4 throttle underload.did all the coil pak epoxy and ran down to .66 and it was still hesatating :angry:
So advancing timing made it seem better it was masking the plugs because @ 25-30 btdc timing it wouldnt lag and the less the timing the worse the lag
But just then i tried .5 copper plugs and went back to 15 deg timing like it should be and POW! no more blah!blah! or power stumble and it even spiked to 13psi without lag :woot:
So guys with std coil paks and problem even try down .5 IMO
Im so happy i have my car back after 15ooo kms of trouble :laughing-smiley-014:
My theory is that weak coil paks and preasure dont mix(blows out spark) so if like me and cant afford splitfires yet try .5 for a tempish fix :)
also i was a bit scared to do up plugs fairly tight(without too much!) but found i was doing them a bit lose :)
<saves for new coils now with confidence thats it :)
The car will be more efficient with a better gap on the plugs.
So you might aswell start budgeting for new coil packs.
The gains outweight the cons.
It will get to a point where even .5mm wont work, so definately a temp fix, thats all the epoxy/tape/small gap ever has been
yes i will save mate.
either it was the gap or the copper plugs?i went .5 straight up <from .66 irids but it alowed me to come back to 15 BTDC
and yes a bigger gap will burn more and economy but do u think power up also?and im talking over 1-2 kw
wow, i would think that .5mm is going beyond border line, is it safe to do for a limited time?? i need new splitfires to but need cash to get them, im looking for a temp fix for about a month, i tried taping coils but it didnt do a thing! my problem was similar to yours, car hesitates after 4500 rpm now to about 6 then powerful again. IM wanting to try this but is it safe? can it cause more problems
problems like what?its only a spark.no like your changing its timing or votage........it may be smaller but under cold extreme presure the small gap has more chance to fire every time and not get blown out.yes a nice big spark will burn better but we all arent rich.im saving now
but my problem was different to yours it never went powerfull again after 6 it just couldnt take WOT under load full stop.
yes it may be crude but im broke atm
maybe going from the iriduims to copper plugs helped also?
well, my tuner didnt seem to think so, and hes got a very good reputation, especially around here and with RB's
Well im glad i dont take my car there :D
I didnt need a gap smaller than .8mm running 24psi/360rwkw on stock coils & ignition as mine were in good nick.
So if you need to run less and think its acceptable, thats your decision. Im just telling you i feel there is an issue wether you want to fix/investigate it or not is again, your decision.
the problem is the coils breaking down but id rather run the smaller gap even if it is a short term solution then have the misfire. Evenutally i will replace with splitfires but given the budget im on, i dont really have any other option..
Well im glad i dont take my car there :)
OMG 24psi @.8 on stock coils :blink:
0.8mm or even closer to 1.1mm would be ideal
Man! your hot! :rofl:
    • Give the fluid a really good flush, then go do the same track again. Report back too please
    • I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
