After having my subframe held in place by the whiteline pineapples,I always new they weren`t really doing that much.So,a couple of days ago I decided to take them from the standard position, which is just bolting them on underneath the subframe,to putting the front ones in between the subframe and chassis.
Well,blow me !! What a transformation.No movement at all.No body roll.No clunks,squeeks or NVH.The handling is so stable I feel like it is a new car.This is the squat position (that sounds weird) and people say the front end will push too much if powering out of fast corners due to unloading the front end under power,but this is not true.I didn`t notice any squating even when deliberately trying to light the tyres out of corners,only traction and handling that is very,very predictable.The car simply rockets out of corners where as before it would simply light the tyres and go nowhere.Mind you,I can still get it to light up but I can apply alot more power now before it does.
Now I also notice my ceramic clutch doesn`t shudder so much nor the rear end feel like it`s rocking back and forward when taking off from a standing start.Also,the car is so much quiter over bumps.Now I`m going to put alloy locking disks in the back of the subframe and see what happens.Will get the traction rods from Just Jap and that should do it.
King springs.
KYB shocks.
Whiteline caster bushes.
Whiteline rear camber bushes.
Unique Auto sports diff bushes.Coming soon.
Whiteline front camber bushes. Coming soon.
Whiteline pineapples.
https://www.sau.com.au/forums/topic/177113-pineapples-in-forward-position/
King springs.
KYB shocks.
You have found that the Maximum Traction position actually does give more traction, how about that. :ninja:
If this is important to you, then I wouldn't suggest
They transmit heaps of NVH
Why would you
when you already have a Whiteline rear camber kit that includes adjustable bushes for the standard traction rods?
Also keep in mind that aftermarket arms usually have spherical bearings which will increase the NVH even more.
:ninja: cheers :D
What about the inside bushes for the traction rods,would that help?I`m on a mission now to get the rear to be at it`s best.I don`t want to get rid of the hicas just yet as it doesn`t really bother me.Driving around today I`m just rapt in the handling.My car has 205,000k`s from when I bought it with the new car smell still there at 22,000k`s.Oh,by the way I have yet to notice the front get light and the rear actually squat.It just puts the power to the ground.
The "inside bushes for the traction rods" are the ones you replaced with the camber kit. The "outside bushes" are in the upright (hub). Replacement arms have spherical joints which replace the "inside bushes", but they don't replace the "outside bushes", so you are stuck with the standard rubber for the outside bushes.
It will.
Depending on the spring rate, the squat can be quite subtle, but it's there.
:cool: cheers :)
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
