ey guys.. atm i am just gettin a new engine put in my r33 gtst... and just got told that my t04e garret turbo is f***ed.. soo ahh... im on the hunt for a new one..as this one is to big anyway..and just causes problems.. so i was wondering.. what are some desent turbo's for a 93 r33 with a boshe 044 fuel pump, 760cc injectors, custom inlet plenum, hks front mount,microtech ecu, 3 inch exaust and headers... i was thinkin about ball bearing??.. and also... the mount on the headers only fits the t04e garret.. can i get some type of adapter or something for a smaller turbo??
https://www.sau.com.au/forums/topic/177117-new-turbo-for-rb25/
Depends on the budget.
Depends on the power aim.
Depends on the conditon of the motor.
Also read this link below, as once you cover the 3 points above, then all you do is look for the results that fit into that.
http://www.skylinesaustralia.com/forums/in...showtopic=55845
There are 100's of threads about "i want 250rwkw" or "i want 300rwkw". So have a good search around as there is a good wealth of past threads with more info than you thought possible.
cheers
cheers
ahh.... the engine is ogin in as we speak..its a series 2 engine and is in good as condition.. my power aim is about 280rwkw or maybe a bit more... and budget is around the 1500 mark about
for that you would want a gt30, slide performance sells them at a damn good price, give him a call
i really like the gt30, but another problem is that it might not fit on the high mount manifold, can i get some adapter or??...
cheers
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
