what are the advantages / disadvantages of running more duration on the exhaust cam?
Two schools of thought;
1. The inlet cam duration is what makes an engine lumpy, by keeping the inlet duration down you avoid unnecesary lumpiness. By lumpy we usually mean rough idle, not smooth cruise, cranky when cold, requires higher rpm to make power etc. The exhaust cam duration has LESS effect on lumpiness, so you can run slightly more duration and not suffer from it.
2. The exhaust valves on RB's are slightly too small when you increase the boost, they are OK at standard boost, plus a bit. But when you start feeding them 1.5 bar or so, the exhaust valve size becomes an issue. Using slightly more duration on the exhaust cam is a band aid for that problem. The real fix is to use oversize exhaust valves, even as little as 0.5 mm larger diameter makes a huge difference.
:ninja: cheers :ninja:
:D cheers :D
thanks SK, your a legend, thats exactly the info i wanted to know, i didnt understand the reasoning behind it but all clear now... thanks alot
