I've narrowed it down to a few choices only....basically i want as much response as i can get from my rb25det, and would like to know which turbo would suit for a street r33....i would like to make a car with enough power to pass a high 12 pass on the 1/4 aswell......maybe 250rwkw will get me there???.....please help guys, heres my 3 major considerations atm:
HKS GT-RS
GT-SS
GT2530
current mods:
fmic
apexi pod
3" exhaust + split dump
bosch 040 fuel pump
splitfire coils
the threads i see about the gt-rs are generally for the rb26 motors, and they say its too laggy for them.....but it seems they are quite a good turbo for the rb25? why is that?
thanks!
Edited by nsta
  • Replies 46
thanks!
This is because the GT-R's that say the GT-RS is too laggy are running 2 GT-RS' turbo's.
One GT-RS would be fine on an rb25.
A gt2530 is a good responsive turbo... if you're running 2 of them on a GT-R lol. But really, this seems way too small for an RB25 single.
GT-SS is again just a little too small.
My vote is GT-RS or GT2871R.
Good luck!
gtrs is a an awesome turbo, but if your looking at turbos that size of what you suggested i would seriously consider a slide highflow, they are awesome for the price and bolt back on with minimum mods. i put one on a mates car and it took me under a day including stocker removal and the thing hauls
I have driven a 33 with gcg hi-flow, and responce was pretty good actually.. full boost by 3.5-4, which ok is a little laggy.. But god damn does it pull!!
hi-flow might be cheaper than gtrs as well..
thanks!, whats the response like of a gtrs?compared to say the stock turbo, which is really reponsive down low.....and will it get me to 250rwkw?, and a high 12 sec pasS on the 1/4?this is my long term goal, and one i dont want to keep changing turbos around for....also how long will an rb25det engine last with a gtrs and that amount of power?
You don't need the MAGICAL 250RWKW POWER to run a high 12 second pass, i've got around 220-225rwkw and ran 12.9 on 225/50/r16 Toyo T1R's @32psi tyre pressure
GT-RS or HKS2535 or a GCG/Slide Highflow would be my choice
You will also need:
-Bigger Injectors
-EBC Boost Controller or bleed valve
-Remapped ECU /Powerfc or the like.
You will also need:
-Bigger Injectors
thanks for that, yeh what size injectors would suit?and is it bad to get bigger than you need injectors???, cause the ones im after....theres no real difference in price between nismo 550cc and 700cc injectors....so should i get the 700cc ones instead?. I have a sau bleed valve, dnno if that will be sufficient, but seems to hold boost quite well:)
and im after a power fc aswell, will i need the hand controller or not?
cheers,
cheers,
for the power you are after, 550 cc injectors are plenty. if you want even more power down the track then you might want to get the 700, but if not, youll be just wasting fuel. If you bleed valve is up to the task then what you have is fine. you will need a good ecu to control eveything and the power fc is ideal and best to get a handcontroller so that you can monitor knock levels, adjust timing if necessary, etc..
Best turbo to do a high 12 pass and the most responsive would be the stock turbo. It has been done numerous times.
Some of the turbos that the guys mentioned above would be way too big and be lag monsters. e.g. the 2540? lag central.
umm a 2540 is just a touch bigger than a 2535 and smaller than a 2835 and GTRS, so how would it be a lag monster??
yeah stock turbo hi flowed would prob be the best....but if faster 1/4 time would prob invest in drag tyres...from my experience a set of 2nd hand drag tyres will take 0.3-0.4 off ur time.....to do that with just power increase ur looking at like 30-40kw...
I've got a GT3071. Pumps 15psi and over 230kw atw by 3200rpm. Stock injectors and air flow meter. Turbo cost $1500 plus oil\water lines and intake mods. All up cost $2000. Is sweet, loves to peel the rubber off by 10 psi
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
