Mate i was in the same shoes you are in about a month ago and it pretty much came down to either a HKS GT-RS or a GCG Highflow. Both will easily get you into the 12s and take your engine internals to their limit without going a forged rebuild. To get the most out of these turbos you will need an aftermarket ECU, Z32, fuel pump, 555cc (or 700cc if you really wanna push the turbos to the limit) and all the other stuff that you allready have.
On a fairly decent amount of boost you can get these turbos up to 250-260 @ the wheels and will both be very responsive. If you decide to go the extra step and take your head off, drop in a set of cams, head gasket and maybe bigger valves you can get 300 @ the wheels on a GT-RS (Not sure on the GCG as i havn't personally seen one pushed that far). However this will take the turbo to its absolute limit and your engine will most likely go bang.
So its up to you, both these turbos will get you what you want and will give you heap of head room for further mods.
Personally i went the GT-RS because it was only a little bit dearer than a GCG (approximately $1900 compared to about $2500). However the GT-RS comes with full braided lines, an adjustable actuator and hell, your getting a HKS turbo. So to me it was an easy choice.
Hope that helps you a bit man, good luck with your choice.
  • Replies 46
umm a 2540 is just a touch bigger than a 2535 and smaller than a 2835 and GTRS, so how would it be a lag monster??
The 2540 is a poor match of compressor/turbine wheels.
They basically make around the same power as a 2530 (a poofteenth more to be technical), but with a noticeable amount of extra lag.
So the extra top end power IMO is poorly offset by the much increased lag.
Its just a shocking turbo match, and as many have found of over the years, there are far more evenly matched turbos for the money out there on the market.
from personal experience with the gcg hi flow i'd recommend them for sure, mine had a single turbo vg30 ex housing on the arse of it for abit more breathing...awesome turbo, regretting selling it, on my engine it made 258kw@15psi.. great bang for buck i reckon
sweetr33 i was told these were a little laggy, cause i am considering following this path.
watching this thread closely casue i am in the same boat
depends wat your view on laggy is.... it didnt come on boost as quick as stock turbo but once it did there was no comparison....there a little power house the hiflow with vg30 rear...you wouldnt be disappointed at all if u chose this option i can assure u
if you go for the nismo 555cc injectors, they are worth around $700 delivered from perfectrun.com.au for an RB25DET
this is the cheapest i've seen anywhere so far, i've seen people selling 2nd hand ones trying to palm them off for this much
Apexi ones are now hard to get, and HKS ones apparently are harder too, according to greenline
Just go for the nismo, no one i know that has them has had any issues, so its win-win
Good luck with your build dude!
shit, 2500 for a hks gtrs
danngg where are these ppl pulling all this cash outta
man 2.5 g's for the turbo
labour, = 400 est
nismo injectors = 700-800
200 labour for that
tune = 500 bucks power fc ( can cost more )
additional bumps = 300
= 4700.00
gcg hi flow = 2nd hand 1200-1400
s15 injectors = 360.00 for 6
install = 400 est
injector install = 200
tune = 500 ( can cost more )
additional 300
= 3160
rough estimates
the additionals are for minor shit like sparkies, fuel, just shit that tuners add
man seriously i'd just wait till somebody sells a gcg hi flow and see what previous sells are etc
buy that
saving up to 1.5 grand is heaps if ur just hitting 250rwkw!!!
remember who cares about MINOR lag , cause ur realli gonna pay that 1.5 g for an extra few hundred rpm spool max??
install = 400 est (should be ZERO, check the DIY threads)
injector install = 200 (again, should be ZERO for the same reason)
Alot of peeps can do this themselves, and even those who can't......well, they probably can, just don't know it yet :(
oho even better at getting my point across.
for the diy's
sums up to 4100.00 for the hks
and 2560.00 for a gcg installed and tuned now hows that for a 250rwkw skyline for 2.5 g's
not a bad bang for your buck i reckon if thats ur aim
:D
Edited by Zas)-(
Ye, and if the turbo had bad treatment in a past life then your up for $4500 once you remove/refit and purchase a new one.
Sometimes cheap is not the way.
ohh you wanna use the term IF AYE
but IF it hasnt had bad treatment then you've saved yourself over 1.5grand..its a gcg not an ebay turbo mate
Yeah, but thats not to say the motor it came off had "average" oil pressure.
How do you know? You dont. Its a gamble, so "IF" plays quite a big part in a gamble, being its often luck of the draw.
Without pulling it down, chucking a rebuild kit through it, your just taking a gamble for the sake of saving what, $300?
Hardly viable when the rebuild costs you more than what you paid for the turbo.
You'd be thinking to yourself you'd be better off going with ebay turbos in that scenario.
I've met countless people over the years who have attained something second hand only to have it fail.
I once was a second hand man also, but once you get stung once and it costs you double, it soon changes your thinking
Good point.
Been stung with a dud Z32 and i wouldn't even buy a replacement from Australia after that :D
Got one delivered from Japan.
Although, currently have a 2nd hand HKS 2535 which seems to be OK so far, fingers crossed.
If it fails (well i guess it will eventually), prolly go the new GTRS as i'll already have all the supporting mods :D
ohhoooo u dont save 300 bucks
you save upto 800dollars or even 600 for some gcgs i've seen ...
, and there many 2nd sellers that arent going to sell you crap? ?? ???? :)
oil pressure wtf? COMEONNNNN your pretty much going to kill the good traders who are selling good 2nd hand gear, that have good selling records
oil pressure....
lol
:thumbsup:
Edited by Zas)-(
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
