Just want to see what sort of Track/Race/Rally Skylines are around. Throw up some spec's if you want.
No streeters please.
This is my budjet build club rally car, setup for gravel and tarmac. -Just running a stock RB20DE until I build up another unit with some power. It's got adustable suspension, 6 point cage, harnesses etc and is fully race and road legal for around $6K NZ.
https://www.sau.com.au/forums/topic/177171-show-me-your-racing-machines/
mine's not a skyline, but it goes ok :D
It's a budget 100% backyard build, using mostly various types of leftover factory Nissan parts from different models.
SR20DE
Did 1:09 flat at Wakefield, (which I am hoping to beat on Saturday) and should be well under my previous 1:54.8 at Eastern Creek in a couple of weeks.
It's currently road registered, but won't be for a whole lot longer. I'm planning to run in Improved Production next year if all goes according to plan.
Ah goodie was about to create a thread like this myself, the more pics the better from any angle of any car as im getting ideas for my current build.
I damaged my r32 gtr drag racing so I bought another street gtr and have decided to keep this damaged 1 as my dedicated circuit car. So far im only in the process of stripping it down (prob another week or so of that) then I need to weld up the damage, paint the interior, boot and engine bay and get some and then start assembling it again.
Nothing exciting but here are some pics of where im at so far:
Hopefully it's back on the road by Xmas time.
Heres my shitter...
Most of you know it, Blown VH45 Powered 33 on methanol, full andra cage ran 10.17 to date on stock internals, new engine is a few weeks from completion hoping for some good 9's out of it.
Edited by NA_R33
Its great to see a few skylines out there racing these days, used to be as rare as hens teeth
here's our little stocker
started like this
second attempt
finally after 4 years of hard work (and money)
and here is one of ours and Mark's car (during the only 4 days they looked like this lol)
and Mark's race car at Autosalon
well credit to Louie at Xclusive colour for the paint job - we asked him for something that would stand out.....
but the stickers are crazy....Kel designed and cut them on a $600 ebay special vinyl cutter
how much was spent?
I believe its gotten so high now that we dont keep track.......if you dont think about it, you cant lose sleep over it.
House in the country.....i was thinking more along the lines of a nice apartment in the city :D
Does yours go simon? Ours goes when its not bogged down with problems.
Edited by r33_racer
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
