Show Me Your Racing Machines
hey stupid toyota
sorry to hear about your head gasket issue, as you say that racing.
i'm sure you'll proably be playing cars on the weekend then too!
what's a decent time on the clubman?
russ
no idea to be truthful the blue patrol is not mine it was just parked next to my car in the shop. Its a sand racer and 1300hp nissan patrol engine
1300hp RB30? DAMN!!!!!
Whats it got inside as far as internals go?
Also how do you stop the block from exploding?!?!
Those sand races are awesome to watch :ninja:
my race machine, this was taken a few months before i banged it into that wall just behind it there in the picture.
r32 gtr on the way.
*drool*
abit of a downgrade going to a gtr?
race spec 600 hp gtr will be quicker and handle easier but be chaeaper to fix after a prang- (cost almost as much too), this tail happy bitch is the best car i ever fanged on a track though (its unchanged from factory and does 12.3's with no turbo), sounds awesome but cost a fortune when somethiong breaks and i broke lots of things. repair bill for current prang more than 100k.
Edited by nedi
damn thats a big bill! i see why you went for the gtr :ninja:
hey john
you dont have time to be on here get back to fixing the head gasket!! :worship:
come to think of it, i should be in the shed too!
cheers russ
LOL, Ive been busted...
I'm taking my time with it I must admit. Barely touched it today, serviced the work ute instead.
Looking into a few upgrades because it sounds like I might be chasing your times again with all the mods you've been making :(
Might even start on a new engine for the car, for next year. Won't go for any more power initially as 2WD is pretty limiting currently. More like less weight, better distribution and bigger brakes.
hey thanks fellas
yeah the car does look alright! they did a really good job because the car was very dirty and looking a little worse for wear after the dutton and that was about a week later.
richard - the stack is great and really easy to read at speed especially whe nyou get a warning indicator come up and the tacho is everything!!!
hey john i dont think you have to worry to much about our times! i have seen your car in action and it's a real credit to you.
cheers russ
sounds good. I will try some rear toe in, and some less caster. I get doug heasman to do it for me. he uses old school equipment. I too had massive problems with laser equipment not being even close to accurate. you put it on the machine 3 times and you get 3 different figures. I mean, they had a workshop fan and when it was on the force of that air onto the car made the alignment readings jump around. after I saw that I gave up on the laser machines and now only get doug to do it with his setsquares and dials. :P
Ive had no problems with laser equipment at the bridgestone i use. I know the guy there as we send alot of business their way, and long story short do the spanner work under the car, watching the figures change untill im happy. I also have someone roughly 70kg sit in the driver seat for me while this is going on.
On the printout you get it lists old alignment and the new. Every time i went back in to re adjust the alignments it had not changed at all from before.
my final settings were(full sk package)
camber front 2.0 neg each side
castor max around 6
toe 2mm out each side
camber rear 1.5 neg each side
toe zero
im pretty confident that if i went back now and put it on the laser gear it wouldnt have changed. Unless u hit a pot hole its really not going to change that much, it would have been six months since ive had one so ill have to get it back around there soon and see.
crap stories aside, can someone show me a pic of these traction rods fitted to their 32 gtr? would love to find an improvement in my suspension alignment area
and giant, your car is possibly the best looking 32 ive seen!!!!
Edited by 2630GTS
castor max around 6
toe zero
it may seem fine. and laser alinger may be top shelf for a truck or whatever and maybe some laser machines are better than others. this was the latest beissbarth machine. maybe 1 month old when I used it. and it doesn't take a genius to figure out where they fall down. they have those 4 massive things hanging off each wheel so the slightest movement with the car or someone farting etc sets them moving and figures bounce around. old school is best. trust me. we are talking tenths of a mil in measurement either so the amount of accuracy is crucial and those type of machines just don't have it.
I'll see if I can get you a pic of the traction rods.
there you go (it's the gold ikeya arm):
    • Hey y'all! So I am the owner of a shiny new '99 ENR34 25GT-Four, 5spd manual. Took it to the tire shop to get new shoes. They mismatched the front and rear axles (225/40s on rear, 225/45s on front), so AWD system went bonkers for the next day. Took it back in, they fixed it, but I noticed about 8-9 big drops of red fluid in my parking spot. Leaking has stopped, but it's clear that the transfer case may have been stressed/hurt by this debacle. I'm taking it in for inspection tomorrow. If things are FUBAR, I have a few questions. - ENR34 manual transmission transfer cases seem impossible to source. Can a GTR transfer case fit? Or if not the whole thing, just seals or components? GTR is 6spd, mine's 5spd, so I'm thinking no, but lmk. - Finding a few RB25DE NEO AWD auto transmissions for sale, for decently cheap. If my only option is to swap to auto, what else will I need besides an auto-specific gauge cluster, and associated wiring? - I imagine the R32/33 GTS4 transmissions/transfer cases are a no-go? They're not NEO engines, so unsure. - RB25DET/4WD setup from the Stagea, any parts that transfer over? I did search up for this on SAU and google, very little info covered.   This is my first post, so apologies for breaking any rules, please let me know, and thanks for the help.
    • Thanks. I agree, looking at those plugs in conjunction with good compression/leak down tests I'm not too certain its ring related anymore.  I have a Swagelok ball valve on the drain and tubed it lower down to the left side of car to easily dump it into a container. I do not drain back into the sump. I've never had to drain it though as there's never been any oil in it.
    • Best bang for buck at the moment would be a 86/brz. Good chassis,  plenty of aftermarket support and parts everywhere.   I just picked one up with some quality gear and it drives better than my old 180sx.    Also depending on what your doing and budget.  An a90 supra is my pick if want to spend more. Great chassis, solid motor, gearbox is good. Development potential is crazy. They are doing well in prod sport and time attack. All the old jdm stuff needs alot of work as most of it all bent and over priced.
    • It's basically the same platform, hence why everything bolts to everything else Kelford camshafts were recommended by Mania after they asked me what I want the car for, I said "I'll thrash it around daily and maybe take it to the track for fun" 🤣 Factory NC 2.0L cam specs: - Adv. Dur. 256 /256 - Dur @ .050 205 /190 - Lift 9.42mm/8.13mm So, as I know nothing about cam specs, all I can say is the numbers are different and it should get a little bit of lope....🤣
    • Depends on how extreme, however if you look at SMSP, they're all dominated by Hondas and M cars on amateur/street car events.
