Show Me Your Racing Machines
yeah you want the car on the ground to check alignment. up on stands is no good. obviously you can jack it up to adjust, but must be on flat ground again to re-check.
oh yeah for sure. what i'm getting at is if you would need to roll back (e.g. 10m) then roll forward to allow all the tyres/suspension to 'seat' then check again. right?
How about using a simple clinometer for camber measurement? Autospeed states the ones picture cost $15 from a marine store, you could bolt it to a length along the side and just rest it against your wheel (maybe with a right angle at the bottom to sit it on the ground).
I actually find it a struggle on the tighter motorkhana courses (although you seem to make it look effortless) but the more open courses I seem do quite well in. I've only been participating in motorkhana and circuit for last three months so i still have a LOT to learn. It's a bit of fun anyway it wouldnt be a car i would use if i wanted to be ultra competitive no haha.
Go the open fuel filler :cool:
paint job looks shmiko on the track, and that balaclarva makes you look very stig like.
Yer just noticed that as well, need to get that looked at. That corner although its doesnt look like it it has about 18 degree of banking have not seen a pic of that corner before, little surprised that the suspension is compressed that far.
heres mine!
spec wise: its got the normal gear power wise 350hp @ 16psi, i've been more focus on suspension and brakes ---> 90% of my suspension arm have been replace with nismo items, got nismo swaybar F&R, aftermarket tierods and castor rods, current has d2 coilovers but waiting for my TEIN RA-spec to arrived (damper and rebound adjustable with 10kg spring rate F&R)... my clutch has just failed so twin plate is on the way, ohh yeah running ap caliper up the front with larger disc.
im pretty much happy with the car atm, just need an lsd and it will be perfect
nothing too special atm, as it was a daily driver but i have since got a nice daily which cost me $20 a week in fuel :thumbsup: so its getting the full track treatment in the near future... cage, stripped inside etc etc
Edited by [Michael]
Ok, so it's not mine, but Jason the owner and I built it, and I get to sit in the silly side :/ No pics of the engine out/suspension etc unfortunately. It's just built to CAMS Tarmac specs. But we wanted a stereo and the aircon still :D
