Finally got the interior all painted... what a mission. I'm still blowing paint out of my nose.
And got my plenum back so it can finally push ahead!
Also popped upa pic of the new box. It's a RB25 box with OS Giken 1-3, along with the strengthened input shaft. It has an ERP Bellhousing conversion kit on it so it will fit onto my car using my current OS twin plate clutch. If this thing doesn't hold up then I have to change my driving style :cheers:
I'm in the market for something similar at the moment... but budget won't quite stretch to that fine example, unless I sold the Skyline... and that ain't happening any time soon :cheers:
funnily enough that's exactly my budget... I think something like this would be spot on http://www.my105.com/classified.asp?id=10635
Edit: I was going to try and build my own but have decided there is no way I would get it on the road without blowing out the budget... I'll buy one already registered and then tinker with it myself... much easier to work on for a hack like me than the skyline... cheaper on parts too
Does anyone have any shipping contacts in the good old US of A? I want to bring in a lexan rear window, but shipping via air is out of the question. I need a container spot or something similar. Anyone?
I'm seriously considering painting mine matt black. Externally. With pressure packs.
Matt did his with pressure packs, and once some signwriting is on it, looks aight.
Any thoughts guys? Too rough?
Matt's 7urd;
http://www.nissansilvia.com/forums/index.p...howtopic=301412
flat/matt black is damn cool i reckon.
was dead keen on doing the evo in flat black, but it turns out cheaper to do the shell gloss white so will press on with boring old white.
you NEED to though benny... and just think, you can swap sponsors on the car with a bucket of water and some chalk!!
Also popped upa pic of the new box. It's a RB25 box with OS Giken 1-3, along with the strengthened input shaft. It has an ERP Bellhousing conversion kit on it so it will fit onto my car using my current OS twin plate clutch. If this thing doesn't hold up then I have to change my driving style :(
Nice work funky, looks great man!
I spent a few hours on saturday with dry ice getting out my sound deadening. Cost me $50 for 14kg and it was pretty much just enough to do the job.
I rekon it took me a bit over an hour :banana:
I have scooped it all into a box, id guess its weight at about 15 kg. Ill weigh it soon just incase anyone is interested.
I NEED to what Stu?
I reckon its a good weekend job, once I have the rest of the GTR sh1t to put on it it's a go :(
paint it flat black... bring out your inner bogun!
if i could do a decent finish with a can i'd do the evo, just not sure if i could get it even enough.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
