heres my big camshafts .....not finished yet....these puppies should make some trunks a bit lumpy
lol, there's a hole in that housing where the port should be mate... hehe. that will be nice. should slot those housings into my road car...
Selling her? Any particular reason? Shame, the thing looked to be a decent little bus, and no doubt well driven.
No particular reason mate, and once push comes to shove might not be able to actually go through with it. But I'm feeling it's time to maybe take a break and show my little lady the attention she deserves. She's missed out on alot over the years due to me going racing.
That porting is massive. Should sound very nice indeed!
It's getting there Scott, hopefully driveable by Monday. I haven't got the dash done yet as a few things have gone over budget, so once that' all sorted I'll pull it out and get it flocked.
I even like the uras type lights on this one where they are covered. it would probably help the aero a bit as without that nice smooth cover it would for sure create drag or turbulence.
says the man with the Stack dash!:)
I'm jealous... I like shiny stuff...
Haha that was in the budget... but a few thousand other things weren't! :(
I think you're right Richard, and it's something I've thought about, but I just don't like the covered ones so I'm not doing it by convincing myself the open ones make for a great ram air intake :P But I should really do it, so I might when I have some more money and can do the aero stuff I want.
Chris: I'm sure some companies would
dunoo, will have to ask him. Maybe google the name above the door if you can make it out.
also, bought this from Revzone in melb.
replacement rear half should be arriving at the shop next week. rebuild imminent. tempted to chuck an SR in it for shits n giggles :blush:
post-256-1247186116_thumb.jpgpost-256-1247186126_thumb.jpgpost-256-1247186135_thumb.jpg
it's funny looking at that porsche it just screamed american to me. I know it's LHD but that's not the give away. it's the cage design. the side intrusion design to be specific. so american. they all seem to do it that way with the ladder type side intrusion. I guess it's come because oval racing is their premier tin top racing and that cage design filters down to other categories. you would never see one like that in aus in any category. except benms lone nascup car which of course was US built or at least designed.
any particular reason why oval guys use that style?
It looks like the ultimate in side impact protection. As Zebra suggests American oval racing has far greater likelihood of high speed side impatcs.
Speedway in Aus requires that design, obviously a hand-me-down from the states oval racing regs.
Just picked up this for a fun track day project:
Will be set up for drift or circuit with fun being the key word, times coming second.
Coming up will be a heavily modified N/A 4AGE. Not too sure yet how I will swing it but I think lightweight forged internals, larger cams, light ported head, bumped up compression ratio, twin weber's in an alloy air ducting enclosure (gogo cad skills!), MSD electronics and a few other bits and pieces.
Suspension wise I am not to sure... More research will need to be done!
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
