Show Me Your Racing Machines
Don't all the shifters go into each 'box?
Benny, I reckon you'd need to make one mate, has YT got you sitting in the back seat?
not really, i was looking at trying to get a comfy position, and i think the gearstick might need to come back...so i don't need to have my legs cramped up
just personal prefarance, like to have the stick close. but once the seat is in i might change my mind. just wondered how hard it was. if i had a pedal box, i'd move everything right back though....but i'm not even temped to spend that kind of money.
Big little engine project is very close to completion now. Had a high-octane sump extension welded onto a factory sump last week so ive installed that today and finished cleaning up and installing a little more plumbing. The timing belt issue has been a bit more of a challange that I had thought it would be. The first belt ive sourced is 1 tooth too long, so im having to order a belt from the UK that normally goes on a vahuxall astra to get the right tooth count.
GTRS's should arrive next week so when the belt arrives it will be ready to install. Cant wait!
looking good mate. :thumbsup:
Thanks Richard. In hind sight Im thinking I should have made a build thread for this engine, but I can always do that later I suppose. I've got timing belt on it now, all sorted. Its a little perverse what engine it came from though.... its an Opal (holden) Barina timing belt.
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
