my project is nearly complete.
engine has just undergone a rebuild and in addition ive added a GTR plenum with ITB to a rb25de+t
ill do a write up once its completed and tuned.
nice!
i'm also running gtr plenum on rb25det, one of the best mods i have done responds in amazing
Here our quick 6 month build going on 5 years. Hopefully finish it next year. It's a dirt circuit open wheeler powered by a 1jz. It will hopefully weigh 800 kg and make 400 hp to be competitive. Our racing is open so anything goes. We are going to run a venturi under the car and also GP style push rod suspension. If Anyone is SA keen to build a car like this or a saloon check out www.dirtcircuitsa.com. We are currently building a new track approx 85 km from Adelaide and it only costs $10 to come and race.
Cheers
Matt
http://i133.photobucket.com/albums/q60/D_S...it/Image288.jpg
http://i346.photobucket.com/albums/p405/GR...arjuly09005.jpg
http://i346.photobucket.com/albums/p405/GR...CNC/finalrc.jpg
http://i346.photobucket.com/albums/p405/GR...carfinalfeb.jpg
Edited by GROWLY CUSTOM CNC
Cheers
Matt
Here's a video of the open wheeler class :-
Well seems my car is back in one piece...now to find a garage for a few days and bolt all the goodies back on and then go start blowing stuff up again :wub: 2010 is looking like it could be a decent year of motorsport provided i can stay in the country...
What i really want is a 993 GT2
Yeah it's pretty damn cool looking isn't it Chris! It's a shame I'll be covering it in HPC coating...
That's a pic of Ian's (Juggernaut1) Full Race manifold, and I've just ordered the same one along with dual 38mm Tial wastegates and a twin scroll 3071R turbo to go onto the 180. Should give me a really responsive 300rwkw's or so, can't wait to get it on :)
how many laps till an sr flies to pieces at 300rwkw? or arn't you going to rev it?
16 or so.
mine has 15 laps of OP under it's belt at 285ish so i expect a bang next time i cross a start/finish line
Them's fighting words Troy! It's on like Donkey Kong... though the nuffer behind the wheel of the 180 might let the team down :D
2.4 hey? Sounds nice! What turbo are you running with it, the 25G?
There is some uncertainty at the moment with work so i dont know if i am back OS soon or hanging around so for the time being its same old same old std RB20 and 20G. But yeh, if the crank, pistons, rods, solid lifters, cams, springs, plenum, 25G, RB25 gearbox, new cooling setup and new fuel setup ever get installed my car should be a fair bit quicker :)
Still have to blow up the std motor though :ninja:
But....But....If you do all that it wont be an rb20 anymore......
Oh and have you taken that bloody GTR wing off yet?
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
