Can't wait to see what my ITB RB20 runs like
Cool! Great to hear you guys are mucking around with the ITB's too, turbo or N/A? Cranked a few more degree's timing into my N/A RB20 and stuck it on avgas a month ago, certainly livened it up some more.
What throttles are you running? ( I may have missed the bit where you've spoken about your setup?)
Another vid, just for kicks:
2nd gear take off btw.
We have made an adaptor plate to fit a RB26 setup, so RB26 'injector plate' (manifold) through to plenum. damo's is on a RB25DE+T, and mine is going on a RB20DET. When we were researching it all I read your thread, your using toyota throttles arn't you?
Very interesting. What's the reason behind runing a 2ltr, class capacity limits?
Yes mine are off the 20 valve Toyota motor. I'm thinking they are slightly too big for the N/A 2ltr as we seem to be struggling for air speed. But in saying that the car has plenty of poke for the moment, just think there is room for imporvement.
The GTR ITB's would be far too much for me, would have been a bit easier to build if I could have gone that way.
haven't post in awhile but here is an update on my setup (almost finish)
Oil cooler setup (note all my fuses, remove the fuse box from the engine bay, just need to setup the box now)
Twin Gtr bov setup
Oil cooler setup + catch can (note no fuse box :()
Gtr Plenum on rb25
Suspensions setup
seat + harness
nismo wheel + gauges (dodgy horn button for now as the car still gets driven on the street now and then)
Still got alot of work to do; new turbo setup is off to get coated. waiting on nismo lsd from japan. Still need to fine tune the suspension and possible upgrade my LCA to moonface so i can run some more camber (currently max out at -3degrees), also looking at getting a moonface lockbar for the hicas (but pricey at $600). Seat is getting replaced with a Zeta 3 (currently Zeta 2). Need to remove all the carpet and the rest of the crap. trying to source a cage but having no lock all j-spec cages are over $1500 due to the cost of shipping, might just end up getting a cams approve one made locally.
Just order a driftbox so i can do some data logging, from everything i read the data logging system it is looks pretty much spot on so should be interesting once its setup and i can review my times and also check out how well im drifting too
Edited by Kaido_RR
As i was sitting in traffic on the highway on Sunday i saw Stu and his bumblebee on the back of the trailer being driven south past camden. I am guessing you were coming from Power Cruise. Please tell me you got some decent footage of the lil V8 singing in the R32 ;)
wtf are you doing in aussie without going to race tracks?
Me?
Hmm, i went to PI to watch :laugh: I got my car back about 6-8 weeks later then planned so didnt get a chance to do the things it needed maintenance wise etc etc...just ran out of time. This working abroad really kills car stuff...lets me buy plenty of parts that never go on the car though :D
Mechanics charge 3 x what the parts cost to install...lol i can butcher all the parts installing them myself for free :ermm:
Yeh, the car really needs an interested party to help me with installing and tweaking the parts. With work i simply dont have the time in Melb these days and a mechanic is going to charge me between 5-6k to install the new turbo setup, manifolds, gearbox, clutch, exhaust, and fancy electroinics i have for her :laugh:
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
