right click, get the properties of the pic...then insert it between :P
for instance
http://sphotos.ak.fbcdn.net/photos-ak-snc1/v271/10/86/1320006294/n1320006294_30026626_9359.jpg' alt='n1320006294_30026626_9359.jpg'>
Did you do NSW Dutton in that year a few years ago?
No, Just opens up at a set pressure eg 1.2 bar the valve opens so manifold pressure cant go any higher, no you dont have to have a wastegate but its a good idea to run them to stop the turbo over speeding.
The Production race cars like duncans run them as a requirement so they cant run more than the factory boost pressure.
Nizpro used to just run a pop-off valve setup and no wastegate back in the early VL turbo days, with success.
No because the full force of exhaust gas is running through the turbine, and with minimal restriction on the comp wheel, than the turbo will spin way harder than what it needs to for the required manifold pressure.
It may help minimize spool time if you had lazy internal gates, external gate will be no different untill the gate opens
Sorry that does not make sense to me, if there is less air there is less spark,less ex gases?
the point of it is to stop to much boost not to decrease power.
if your car runs on 8 apples. the turbo spools up to 8 apples then it finds that A) the waste gate wont let enough apples past or B ) you have restricted boost for a comp.
in point A the turbo keeps spooling to 10 apples and pop goes the engine or you add in a pop off valve and it lets 2 apples out keeping the manifold pressure at 8 apples. its not designed to let 10 apples out of the system only a few so it just regulates the boost.
with only 8 apples in the system the turbo still trys to produce more but it can because they are being let out.
hope that helps but its realy a question for the forced induction party not the show us your racing machines people.
My r34 at yesterday's track day.
Had my ass handed to me by a pack of evo's. 6th in class D, out of 8 cars. If only having the prettiest car took seconds off your lap time....
Wow, what refreshing honesty! Nice post mate :)
Very very nice looking car too!
'course it's nice! it's my old car. ;) ;)
man you are looking after her mate. it looks stunning. :) and yes way better looking than any poxy lancer.
Those crappy Falken Azeni's you are running aren't helping your cause. If funds allow, try to get some newA050's or even RE55's under that R34 and look out EVO's!!
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
