  • 4 weeks later...
Finally got to take the Silvia out and have a run with the new MCA suspension on the weekend. Worth every cent is all i can say the car was awesome to drive, we unfortunately had to retire after stage 2 with a burst water line under the plenum that we couldnt fix in time but was 2nd outright behind an evo 9 untill then.
Go the S13!! So good to see a cool RWD car ripping it up against AWD evo/rexies!
spewing about the retire Jase :laugh: next event you'll smash it!
Thanks guys, thats most likely it for me this year but will be back next year though ready to chase down the AWD's
In car from stage 1 can be found here
Well I finally got my R32 GTST out on the track for Time Attack at Lakeside on the weekend.
Never having driven the car I started off slow and was building up speed.
Blew a turbo and diff for the day and retired early.
Still had a great day and at least I didn't hit the wall. Thats racing.
Posted a 1:12.3400 for the day and still had an excellent day anyway.
nice man.
it always a good feeling taking a car out for the first time, shame bout the turbo though..
with the cage did you bump it with the hemet much? was it annoying? asking cause i think i will with mine.
Cage was a pain in the arse. I have the seat as low as I can. I am six foot and can't really see the front left side of the bonnet. The whole time my head was either resting or bouncing off the cage to the side above the window. Probably wouldn't without the padding. I will have to find a solution.
Madly sourcing parts to hopefully get another round in before the end of the year. Not sure I will but otherwise back in force next year.
i know its not tarmac but here is a pic of my dirt circuit chassis and engine build so far.
chassis runs quickchange rear end and full coilover plus 5th are suspension set up i have a ve commadore body to go over the chassis and the motor is a 308 with lots of goodies . i know its not a skyline or even a turbo lol so dont flame me :-)mmm says i cant upload this type of file ? any ideas its a bitmap bmp file ?
Edited by mid life crisis
Sounds interesting. Try opening the bmp in Microsoft Paint, then go to the File menu > Save As - save window will show up, change the "Save as type" drop down menu to "Jpeg" - save it somewhere like My Documents and try uploading your newly created .jpg version.
try again lol
ah got it cheers all
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
