a few years driving sprint cars and driving on the roads over here is a perfect combination.
nice looking car chris
20 yrs driving super sedans and now dirt circuit it cures ya fear of most things lol
FFS...get your car back on the road! :cool:
lol, fair call. soon my pretty. soon. you're welcome to come help. the more pissed people working on it at once the better I reckon. :down:
lol, fair call. soon my pretty. soon. you're welcome to come help. the more pissed people working on it at once the better I reckon. :(
I think you've just lost faith in the car Richard. That happens when your pride and joy has been off the road for too long. Someone needs to lend you the keys to a nicely balanced R32 and let you go for a strap so you can get some motivation going again.
Dont know about pissed people working on it though... Ive seen results from that end badly.
yeah me too. that's how the car got into the garage in the first place!!! lol. me dissasembling it half pissed, then decided it needed a mega engine (instead of a $300 fix) and it just got out of control from there. the problem has been too many other good cars to drive in between. but now I've scaled back and it's time this 32 learnt to fly again. :mrt:
Big little engine project is very close to completion now. Had a high-octane sump extension welded onto a factory sump last week so ive installed that today and finished cleaning up and installing a little more plumbing. The timing belt issue has been a bit more of a challange that I had thought it would be. The first belt ive sourced is 1 tooth too long, so im having to order a belt from the UK that normally goes on a vahuxall astra to get the right tooth count.
GTRS's should arrive next week so when the belt arrives it will be ready to install. Cant wait!
cant wait to see thins finished man,
been thinking of this myself, rb28crank and deck spacer to get a good rod ratio.
please pm me if you are going to be producing these, would like to know more about costs and worrk :P
thanks
simon
thanks
simon
That makes two of us Simon. Im having parts supply issues with sourcing a twin EGT sensor system that has to be fitted to the manifolds before they go onto the engine. Once the arrive the engine cain finally be finished and put in the car. Match ported the stock manifolds to the GTRS's and the head last weekend but the project is at a standstill for the moment.
If you have an RB28 crank, i'd be more inclined to keep the block a closed deck. The whole point of using an RB30 or RB28 crank is to make the stroker kit cheap. If HKS/Tomei kits were cheap everyone would have one. De-stroking the RB28 to a little under 81mm and using good quality (pauter, carillo) RB26 conrods, SR20DET GTIR bearings, and a set of custom 26.5mm height pistons can get you around 2.9lt. Depending on the gudgen pin height you may end up with a positive deck, which running a 1.7-2mm gasket will solve. This combination with some HKS2530's or -5's would be awesome for the street and short track.
I wouldnt be concerned about the rod ratio, just dont rev it past 7500. People always get so hung up on rod ratios and focused on the negative effects (cant rev it, engine wear etc). But the positive effects are also equally as good (massively improved cylinder filling make a huge improvement to low end torque).
Yes I do intend to sell these in a pre-assembled kit form but thats a fair way off. I want to have my prototype in the car running for some time first, and I also want to find someone to run a second prototype 3.2lt version in a drag car for me as well. Hopefully this can happen early next year. Thanks for the interest.
haha, perfect , thanks for the answer man.
yeah i have a friend thats going to supply me a new farndon 2.8...basically what the hks step 3 cranks were i think (you wouldnt believe the price im getting it for.....allitle more than a stock one costs). propblem here is....:P.....head is being built to take over 9000revs, big 278 - 10.8 lift cams, so, im very very scared running 1.5 rod ratio on a high revving 1.6-1.7 boost engine ....
obviousley cant be asking for a 60.000 km engine, bout woul like it to last quite a bit.
not shure if i should be posting this on this thread, but i have so many questions i cant find answers for hahaha, such as, if i went for sr20 rods, that would make a pretty acceptable rod ratio with a 77.7 crank, but arent these rods alittle wide? or would the crank have to be machined for them? would an open deck engine hold high revs without distorting? haha, been thinking about doing a high deck for so long, and now my engine is in bits and long time to finish it, its one of those things i can have on my to do list hehehe.
thanks again
simon
thanks again
simon
those cams and those revs are going to put alot of stress (read wear and tear) on ur valvetrain and other engine components. you really should look at atleast an annually tear down regime to keep everything in check and to avoid any catastrophic failures.
hot off the press
Flippin awesome! :)
A little different to the 2700 buck track nugget we just picked up...... we call this one "the 5k challenge", will be interesting to see how quick it is once it's down to around 950kg :(
Fast through corners, slow on straights. But still fast enough to ruffle a few feathers at track days :)
950 is still on the heavy side for a levin isn't it?
Can i suggest making it obnoxiously loud. That was half the fun of my car when it was NA.
Edited by badhairdave
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
