Ahh ffs!
Why did you swap the gasket anyway?
We pulled the head off after Winton as it had a tiny oil leak coming from the top of the oil pump. When we pulled it off we found it to be from an unused bolt hole as it's a GTi-R pump. We tried using the same gasket again as it had only just gone in and there was water in the oil, so we got another one and now it's leaking again. Engine is out now and getting pulled down today to see what the go is. I'm just hoping it's not the sleeves, but the engine builders don't seem to think it will be.
So draining.
Shit Dane!!
Hopefully your luck will change soon mate! Sad to hear that you're still having a few minor issues with the set-up
I was sooooo hoping to see it at DECA yesterday.
Thanks Al. I was hoping to be there too mate, but no luck lately... :)
Gees Dane....you'd have to be one of the nicest guys on these forums and yet you have the worst luck. Hope its not too expensive!
And I just made the comment on NS.com after you posted your dyno sheet that I was glad to see you had the gremlins sorted. :P
it's one of those things with race or modified cars, you're in the hands of the people you trust, so hopefully those people do right. ;)
Indeed mate, just hoping I forget about all this once I've got it back as I'm pretty soured on the whole thing. Lucky I have the car in my posession at the moment though, it reminds me why I don't just strip the thing and sell it... I love it too much :(
Thanks Ian. I'm not planning on paying for it, I've already paid for a completed, running engine and have yet to receive one!
I was just wanting to test out the 285rwkw's before I decided what to do with my turbo kit but no such luck.... :(
Yeah Dane, rotten streak of luck you have. I thought I was the only one with that kinda luck?
I've always had some rotten car luck, I don't know what it is about me! I guess I should have realised the signs when I had two cars stolen in 3 months when I was 18 :D
Indeed mate, just hoping I forget about all this once I've got it back as I'm pretty soured on the whole thing. Lucky I have the car in my posession at the moment though, it reminds me why I don't just strip the thing and sell it... I love it too much :D
I was just wanting to test out the 285rwkw's before I decided what to do with my turbo kit but no such luck.... :thumbsup:
welcome to my world Phunk. Sorry to hear mate. it sux.
Couple of the Evo III taken last night now its finally all back together!
Took it for a drive and remembered why I always loved these things, shame I have no time to use it!... so don't be scared to make an offer!
http://www.my105.com/12415
Here's one we have just finished and just started testing:
http://www.gtr.co.uk/forum/127197-r-i-p-s-...first-pass.html
Build up thread:
http://www.gtr.co.uk/forum/125363-worlds-f...t-complete.html
Rob
just awesome! it looks great Rob. can't wait to see more video and hear the beast in action!
Edited by hrd-hr30
So, it turns out the sleeves have dropped slightly in the cylinder causing the leak. Because the head was decked last time i was off, but the block was not decked with it there is a slight variance and apparently not uncommon when removing the head for the first time in a sleeved alloy block.
So the bores are getting a hone, and new rings are going in as well as bearing most likely. Any suggestions on rings? I was using CP rings with the CP pistons but have heard there may be better out there, but I may be limited due to the 90mm Piston size. Any suggestions welcomed :)
Dane, when I had my block sleeved they decked the sleeve to sit slightly proud of the block to compensate for any slight downward movement in the sleeve. So they deck the block first then instal the sleeves and then deck the sleeves to sit slightly proud of the block.
I used CP pistons and rings too however, I think someone on this forum mentioned that ACL rings had more tension against the bore wall which is better to minimise blowby. Still CP rings are widely used and seem to do the job.
Edited by juggernaut1
Ahhhh ok, that's what may not have occurred, causing my issues.
Do you get much blow by? Mine blew the dipstick out on the dyno, hence why we were considering new rings. It may have been the slightly scored bore though. I'm just considering all options as I want it to stay together this time!
Looks nice mate.
What's done to it?
Engine:
SR20DET 65f s14 block, bored and decked, modified to suit.
S13 52f head, ported and modified, new guides, valve seals & hydro lifters
Hks step 2 cams and springs In264 Ex270
romac adj timing sprockets, Iwis chain and new guides & tensioner
Acl Forged pistons & rings, std Race series bearings, mls gasket kit
Eagle forged rods, Arp main and head studs & rod bolts
Powerbond race underdrive balancer & lightweight pulleys
S14 65f crank, crack test, modified, lightened full balance and linish
Oversized sump, modified oil system & New oil pump
GREX oil cooler, thermostat and filter relocator.
Low mount s/s manifold, s/s twin dump, full s/s exhaust & extra muff
GT2576r .86ex, modified wastegate actuator & bracket, HKS evc3 ebc
Gktech braided lines, RAS & coolant overflow
s/s 2.5'-3' pipe work, 100mm fmic
Microtech Lt8, dongle & dash
53lb/hr top feed inj and fuel rail
Malpassi reg & Bosch 044 intank
Suspension:
Tein SS coil overs F6kg/R5kg
Front tension rods
Adj rear traction/toe/camber arms
Rear sub frame locks
Front strut brace, Rear toe brace
alloy steering spacer
Wheels/drivetrain:
Drifteks 17x9.5 +15
235/45 255/40 federal 595 rsr,
5 stud conversion, custom front hub, skyline rear hub.
R33 front calipers and rotors
Project MU HC+ pads
Slotted rear rotors
S14 front brake lines
S14 gearbox
C's short shift
Exedy twin plate
Os giken 1.5 way
R200 4.3:1
Visual:
Full vertex kit
Dmax front guards
Matt black FRP Vented bonnet + aerocatch
J square headlights
some grill i found
2x dodgy JJR race recliners
Bride and Recaro super low mounts/rails
4 point harness's, Gketch steering wheel
4x Hks Chrono series white face gauges (oil+water temp,oil press,boost)
Microtech dash incl 4 shift/warning lights
white face EL gauge kit.
Power:
320rwhp@18psi
    • Oh bugger ! Your right ! Good old hydrogen sulfide. Takes me back to the good old school days !
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
