He had it there on the weekend - the red one that is.
LOL JFK and I had a discussion about how V motors are gonna rule all when he finishes his new GTO and I finish the Z32 :D
Extra torque for the win :P
Didnt an R35 do ok?
I think the guy on the tiller was driving somewhere else. He didnt seem to be at Phillip island despite the car going around the track :D
v motors won nothing on the weekend. every class was won by an rb26, or a straight 4 :D
Has to be one running to win Duncan :P
Edited by Tektrader69
Did the Radical have any problems on the weekend?
Radical was pretty reliable. Only sticking point was getting the right side rear alloy wheel nut off. Neil busted his 3/4 Impact driver which he uses to run up the wheel nuts. It was stuck on TIGHT.
The anti sieze wasnt quite up to it and the right side rear nut bound up tight on the hub there was a fair bit of alloy galling between the wheel and the nut. We tried everything to get it off. Ended up drilling it out so we could undo it. Pity was Neil missed a session cause of this.
But the new tyres he put on after this where fanstastic he said. :P
yeah I think Neil's biggest challenge once the wheels were changed was the same as mine the week before - its just a hard track to get the hang of in a couple of laps.
I had the big advantage of racing there the weekend before and having had a week to think about all my mistakes lol. there's no mistake the track rewards comittment but I needed heaps of laps to get any idea of what speed I could carry, where.
ahh i wish mate.
1. no restrictors, i remember the bsm guys saying the production car made more top end than the ipra car. which i reckon counts for plenty at PI.
2. i was running dunlop dz03 not yoko a048. that has to be worth a minimum of 1 sec alone.
but i was still stoked about the time, I went quicker than I expected to and no doubt there is another 1/2 sec in it with a heap more lap's worth of practice
nice work dundan! 1:48 in your car with what power etc it has is damn good mate. and quicker than neils radical! that is a big surprise for me. I know his isn't the latest one etc but they are still bloody quick so you must have been peddling your car pretty well.
Good to see everyone is having fun, taking home straight cars and even got the opportunity to play with a bucket and spade. By the way, What the devil made you spin in that direction on/from that part of the track, Were you drifting the kink again?????
No photos yet but my Xmas rebuild is well underway with the motor n box out. Crack the motor open tomoz and see how it all measures up after 3 years of caining around the tracks. I expect a set of rings is all that will be needed. Hopefully it will be back together ready for next years Super Sprint Nats, at Morgan Park I think?
hey guys i was gonna start a new thread but ill ask in here as the main people in the know read this thread...
wheres the best locations for the harness points on a 6 point harness? its in a r32 gtr and im running a fullcage and cobra fixed back seat so the main ones will go around the taxi bar, but what about the other 4 points? I found threaded holes for an eyelet on the sill side but no point on the tunnel side to connect one too. Unless i use the stud from the original seat mount? Then what about the points for the 5th and 6th points that run between the legs? should i just put it to a couple of eyelets that are mounted with a plate on either side of the floor pan for strength and bolted in?
hopefully that makes sense, i just want to make sure i pick the strongest points possible and im sure others have set these harnesses up plenty of times. :D
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
    • I was chatting with an ex SAU person who is involved in chooning euros now. He was saying the factory cars like Audi VW etc have something like 2000 tables that the ECU uses for getting everything "just right". Compare that back to any aftermarket ECU, and you'd be hard pressed to surpass 50 lookup tables. Even the Ford Barra engine has a few hundred lookup tables to run it (and they're still working some tables out too!)
    • Grab a temp probe, and probe each exhaust inlet runner with it sitting idling. Each one should be pretty darn close to the same temp. If you've got some reading higher or lower than the others, it's likely either air flow isn't equal, or your injectors aren't equal to each other.   The other things to check, is from the wiring changes that were made, were any earth's or grounds moved/changed.   Lastly, for the strut brace issue. It's not perfect, but can you get away with slipping a washer or two under the strut brace to raise it, and it still clean the bonnet? If you can, work out the height you need, that the motor can't torque up into, and get a spacer made for each side.
