Heres my ongoing RB31/26DETT build, planning to give it a toss about at some more or less local tracks :blink:
RB31DETT! Thats my project !
Here's the latest of my RB31. The engine is on a test rig and is ready to fire up. With the exception that I need to put dump pipes and an exhaust on it, and dynabolt the rig to the floor. Hopefully not longer than 2 weeks till I get that sorted out.
cool rig mate. :cool: looks good. are you going to run some kind of flywheel brake? and I guess you will be plumbing up the intake side with an intercooler as well?
should be fun running it on the rig. :)
Thanks Richard. I'd love to have a water brake to hang off the back of the rig, but its just not practical for what im doing at this stage. The main purpose of the rig is to run the engine till hot a few times and confirm that I dont get cross fluid contamination between the oil and water, or any leaks... ie that my spacer plate and gasket systems work properly. Once that is proven I can bolt it in the car and start having some fun tuning it. Im not woried about the sleeve or head gasket setup at all. Im very confident that will about 900hp reliably before the top end is anywhere near letting go.
The ecu is an old V400 wolf running map sensing, 3 bank injection and waste spark ignition. Ive setup the rig so it can start R32/3 or R34 engines. I'll just be putting a filter over the intake to the plenum and thats it. The engine is currently all taped/sealed up still.
The project has taken way too long to get to this stage. I had some hold ups when I bought a house recently and then accidently caught the renovating bug. Im back in the shed playing with engines again now though. I have a closed deck 2.8 and another open deck 3.2 in the works as well.... too many projects.
The car's still going great too. Scored some 18x10 TE37's and semi slicks for it recently too. I'll be competing in a few sprint series's this year and intend on being competetive against the evo's. Will post some update pics of that soon.
Cheers!
Ian,
Are these engines you are designing and putting together using standard modified (re-ground) cranks?
The one above uses a modified RB30 crank, with the rod journels offset ground and widened to SR20DET dimensions, and slotted to clear the oil squirters, plus it has the usual standard mods. Jun pump drive, drilled and grub screwed oil galleries, precision balance, etc. This engine is 87x87=3104cc, and the same rod/stroke ratio as an SR20. Its possible to go a little larger on the stroke, but you start getting rod to sleeve interference issues past about 88mm.
Here's a couple more pics of the other project again. Yes its a VW so I hope you all dont get sick! :blink: I finally got the engine started last weekend too. Its been nearly 3 years ive had the car off the road, and virtually every part of the car is custom now Most people can't spot the standard parts. There is about 8 of them! Entirely custom chassis, porsche 968 brakes and suspsension, 930 tranny, 4 stage dry sump system, and a custom VW "oxy boxer" based 2.5lt twin turbo'd (8cm T517z's). My dream now blows flames!
hell yeah... that's a work of art, love it
there's a show on cable at the moment called Beetle Crisis... all about modified and restored Beetles etc... but yours is by far the coolest I've seen!
I've got those turbos on my GTR, can't imagine how mental they would be on a lightweight, RWD beetle racer!
Looks like a well sorted R33 . Go give it a trash and post up some vids :(
here you go roy
its very laggy... but seeing as im running my old tune which was a completely different turbo it isn't too bad. spent the most of the night fine tuning the suspension and was pretty happy with it by the end of the night, only problem was my brake pads was completely gone so i was taken it easy and not braking too hard.
Edited by Kaido_RR
Here's a couple more pics of the other project again. Yes its a VW so I hope you all dont get sick! :banana: I finally got the engine started last weekend too. Its been nearly 3 years ive had the car off the road, and virtually every part of the car is custom now Most people can't spot the standard parts. There is about 8 of them! Entirely custom chassis, porsche 968 brakes and suspsension, 930 tranny, 4 stage dry sump system, and a custom VW "oxy boxer" based 2.5lt twin turbo'd (8cm T517z's). My dream now blows flames!
Thought you may like this: http://speedhunters.com/archive/2010/01/13...vw-1303-rs.aspx
boys this is my new race machine
me and my dad built it, not finished quite yet but will be finished with in the mouth.
and that's it for now
hope you guys like
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
