btw....what is still to be done??? when and where to debut it? I'm sure you know getting it to the first day is really only the first step, still lots of work getting it to handle well, will be a very tidy runner once it is sorted
looks rubbish. try harder next time
LMFAO !!!!
My update: The FD is still in a million bits, but hopefully on the track post-Targa; on the bright side I sold the Evo III and its doing Targa in a few weeks with new owner... on the dark side I bought yet another FD and this one is now in two million bits... may see the track post-Targa 2020 !!
To reply to you duncan, the new intake has to be built and the radiator has to be dropped three inches.
Also i have been waiting for the new balancer and cam gears from the USA
this is the 180SX wit the sledgehammer rear gaurd flares done! Its now as near to finished as its ever been. If anyone has some Type X bumper extensions for the front gaurds that would be tops!
Lakeside tomorrow :blink:
small updates,
finally got my 4inch intake pipe made up, also in the processes of making a box for the airfilter
Also test fitting the new kit
going to run the bn sport kits for drift events (suits the style lol) but will run my nismo bar on time-attack. Will have to make some ducts on the bn bar as the open sections are HUGE! but try some ducts to the brakes
Took the car to the track few weeks ago, did a 59.0 seconds on the short track at Barbagello, was a very interesting drive, running my old tune. was only using the wastegate spring so running 16psi and running the old tune which was 18psi on a 2835pros very very laggy, full boost at 4000rpm and every gear change there was lag, Also my endless pads started to die after the 1st few runs so had to take it easy on the brakes.
However the car was awesome the next day for the drift prac. amazing at the amount of speed i can carry sliding :D
Still got along way to go regarding suspension setup.... Finding it bit hard to get any info in regarding base setup so me and my mate (who is a ferrari mech) have just been playing around with things so far we have gone with 38psi f/r, dampers +8 and rebound +10 front , dampers and rebound +10 rear (from the softest setting). I was happy with this car was very balance good grip. Will need to change things around for drift as the front end is alittle to grippy and pulls the front end into the apex too much.
but overall really happy with how things are going :happy: its great to be able to get back on the track after being away from it for 3 years
Edited by Kaido_RR
fark me you had some pace today, was great to watch.
My shitter at carnell the other week. I was going to go to lakeside but blew it up at QR yesterday.
Maybe we should start a black 180 car club :D
hell yeah, the black 180's were out in force yesterday! shame yours didn't make it. It looks good - the CA front bars are so much tougher (and more practical) than the SR front bar. I have a good stock 110,000km SR20DET blacktop in the shed if you're looking for an engine?
Ahhhhh Harry, I was looking for an SR20 a few weeks back! Pity I didn't know :D
I was trying something new......... Air cooled RB25, didn't work out for me ;)
Massive split in heater hose/turbo water line and cooked the engine bad.
exact same way I killed my last motor
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
