I haven't Chris sorry!
Now, what about this? Yes, I know it's a 4 door, but does anyone know what brand these rear flares are?
get em off jap yahoo etc for about $200 they are mostly all the same modelled off 260z ones as fair as i know.. justjap etc just buy them in and sell em for $350 or so
Thoughts lads? The dollar being strong gets these delivered at under $2k in 18 x 10.5. Weighing 8.93kg each.
They really are cheap ey! I've been thinking of them. Can almost buy 2 sets for the cost of TE's!
That looks nice :) lol
Thanks Damo..... I think you should tell Benny to jam it for a bit and come spend a month up here.... free board, food, and piss :rofl:
yep i like that idea. ive never been that far north. i should have come up for toolies.
i just have to finish my car first. see you in a few months.
on the guard front "bolt on" flairs wont do the job by its self. most of the drift buys hack away all the guard under the flair or wide body guard. i have a few differnt sets of flairs in the shed waiting to go on. one set is a S13 set and they dont fit all that nice. i actualy got some flairs off an early celica supra. but thers a heap of work to get them rigth to.
if you find someone with the right skils a propper metal flaired guard will be just as good as any bolt on flair and more practical.
Do it Ben! RPF1 is one of my Fav wheels!
i likeis too. its funny as they have been around for a few years but have only just become "fashionable" i think it just takes one persons with the right car and the right size rim to really set a wheel off.
the TE37 has been around for years and then one day they were the best rim you could get. then the work XD9. but i think that the pan speed does wonders advertising the volk CE28Ns. if that car never came out wearing them than i dont think people wuld like them at all. i think the current style is dish but with a modern spoke designe where as a few years back it was the tapered spoke of the te37s and lmgt4s that rained supreme.
I'm with you there Dane, both are timeless.
I priced the Forged Advans that are on Berry's thing.... hmmm, too rich for me at around $1k per corner.
Anyone know where to buy Volk the cheapest? TE37 is still the stongest wheel available, their later stuff pales next to them.
I'd really like a forged wheel as Giant tells me I'm "hard on the gear"..... but not if they're twice or thrice the price!
And sorry I've kinda taken over the thread on this subject.... I don't think it warrants a thread of its own :happy:
Edited by Marlin
Yahoo auctions would be your best bet for TE's Ben. You should be able to pick some up second hand in good condition, but would still be more than the Enkei's me thinks.
If not, then perhaps some NT03's??
You are Hard on the gear.. Admit it!
If its pure cosmetics then its up to the individual. But if you want the best track rims then sadly its TE37, GT4 or in 17" TC05s. They are forged, light, durable, and have the biggest internal clearances for brake setups and lower temperatures in operation. CE28s dont clear brakes as well, ditto the Enkei range of wheels. It sux that all the Work rims are pretty much heavy cast jobbies with sh1thouse brake clearance.
I have never tried the NT03, so would be interesting. I would love a set but they are carnts to clean.
So, as much as i dont rate TE37s, since Marlin and Bel180, Baron have MY TC05s, which in 17s actually clear some 355mm brake setups....well its what I am running
I can hand them back to ya mate if you really want them?
And Timmy, do you really think so? I thought when we used to chat in the car you said I was really smooth? Or were you referring to something else? Maybe my chest? Or with the laaaaadiies?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
