yeah you want the car on the ground to check alignment. up on stands is no good. obviously you can jack it up to adjust, but must be on flat ground again to re-check.
oh yeah for sure. what i'm getting at is if you would need to roll back (e.g. 10m) then roll forward to allow all the tyres/suspension to 'seat' then check again. right?
How about using a simple clinometer for camber measurement? Autospeed states the ones picture cost $15 from a marine store, you could bolt it to a length along the side and just rest it against your wheel (maybe with a right angle at the bottom to sit it on the ground).
Hows it go on the race track lauren, ours sucks (although we snuck home 3rd behind 2 race cars at the road event the other day). too much understeer
Its fun at motorkhanas though..... http://www.hgeconsulting.com.au/khanazed.wmv
I actually find it a struggle on the tighter motorkhana courses (although you seem to make it look effortless) but the more open courses I seem do quite well in. I've only been participating in motorkhana and circuit for last three months so i still have a LOT to learn. It's a bit of fun anyway it wouldnt be a car i would use if i wanted to be ultra competitive no haha.
Oran Park. 2 sprint races on the sat, and a sprint and a 1hr enduro on the sunday.....hopefully we can last an hour on a tank of fuel this time, last time we had to retired about 4 min from the end
Go the open fuel filler :cool:
paint job looks shmiko on the track, and that balaclarva makes you look very stig like.
Yer just noticed that as well, need to get that looked at. That corner although its doesnt look like it it has about 18 degree of banking have not seen a pic of that corner before, little surprised that the suspension is compressed that far.
heres mine!
spec wise: its got the normal gear power wise 350hp @ 16psi, i've been more focus on suspension and brakes ---> 90% of my suspension arm have been replace with nismo items, got nismo swaybar F&R, aftermarket tierods and castor rods, current has d2 coilovers but waiting for my TEIN RA-spec to arrived (damper and rebound adjustable with 10kg spring rate F&R)... my clutch has just failed so twin plate is on the way, ohh yeah running ap caliper up the front with larger disc.
im pretty much happy with the car atm, just need an lsd and it will be perfect
nothing too special atm, as it was a daily driver but i have since got a nice daily which cost me $20 a week in fuel :thumbsup: so its getting the full track treatment in the near future... cage, stripped inside etc etc
Edited by [Michael]
Ok, so it's not mine, but Jason the owner and I built it, and I get to sit in the silly side :/ No pics of the engine out/suspension etc unfortunately. It's just built to CAMS Tarmac specs. But we wanted a stereo and the aircon still :D
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
