My old car had high rollcentres which is actually quite dangerous, I reckon if the roll centre is under the ground then the car can't roll above the ground! :)
As you found out, that isn't true. High CoG and low CoR = fall over (technically called excessive roll couple).
Cheers
Gary
Way to ruin my stupid joke with facts and reason and logic!!! :wub:
To be honest I think the main problem was too much Peugeot.
pauls twoogle , is one beautiful looking r32 too ! it's a credit to him.
ross, yeah, the oil to water oil coolers are great, we are seeing much lower engine oil temps now! before we were seeing up to 130 degree's!
cheers russ
+1 for twoogle. Looking good on the DVD too Russ again well done.
Also thanks for the info i think ill get one as it can get hot here in wa.
lol. you crazy kid.
laurence.... world famous gaijin drifter and amatuer stunt driver extrordinaire
+1 again. :D Laurence hope your trip home was good.
Ross
i have ordered one of these Maple A-1 Gages, should arrive in a few weeks. will keep everyone updated once i get some camber & castor bushes in.
anyone know the equations required to calculate castor?
Hey mate, how did you go with this kit if you don't mind me asking?
Cheers
Dane
I finally went past a newsagency and got my hands on a copy of HPI with the ignition DVD...
Hioctane GTR OMG!
the incar footage of that thing is something else!
The full lap of incar is incredible.
great work guys, it will be damn interesting to see how things will pan out with a few hundred less kilo's in the car.... or another car for that matter.
and perhaps some super sticky rubber, similar terminal speed to the Msports GTR says it all.
i can't get over that.... :blink:
Cheers
Dane
in my final year of uni so i've only had fiddle with it - but not on track just yet.
i've spoken to sydneykid and managed to work out a few formulas to calculate the necessary alignments. the thing is there's nothing to compare it to - cant even go in to get a laser alignment to confirm the settings.
so far so good, from the minimal amount of play i've had i have no doubts that i've got the exact settings it tells me i have.
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
