hit the bank then rolled? still looks driveable to me you big girl :teehee:
yep, managed to drive up the bank on the exit of a nice simple open corner, and barrell-rolled off the top... it probably was still driveable, but the driver had had enough!
Cheers G T R, i think i saw you at lakeside on monday. Does your 32 have the black rays rims with the red writing around the center?
Zennon: Yeah its still rb20 powah at the momment. In my first session on the sprint i ran a best of 1:20, next session i ran a best of 1:16 my next and last session was a best of 1:12.
On the national track i only had 1 session and my best was 1:37.
I could make a few excuses but i achieved what i set out to which was to
a) go as fast/hard as i can without destorying the car or oiling up the track and making a dick of myself on my first day out there
b) not come last :wacko:
Hopefully ill be out at the nissan day to help out but my work hours are changing and i wont have tuesdays free anymore :)
More RB20s out there the better. Though i read Gts30t is going to the darkside, if nothing else the user name change hints at something fishy. So think you shoudl stick with the RB20, your car will be much quicker with the money spent elsewhere on the car!
I post this a lot, but is pretty good indicator of how the RB20 can do the job better then anyone credits:
Comparison is both against RB25 NEO engines, both with GCG Hi-Flows, Bass Junky with same tuner and dyno and Poncams. Now tell me that the RB20 with the right diff ratio and turbo cant match bigger displacement RBs to the point where they are a huge hindrance.
LOL, stick with the RB20! Sooner or later you will ditch it, but shouldnt be on the must do list unitl lots of other things have been done :D
A hks 2530 makes about 210 rwkw. Need to get some injectors and have it retuned though, the guys at the last track day told me it was pinging a fair bit.
What times have u run around there?
I have only ever done the sprint track - and haven't been there in ages.. best i've had is mid 62's :D
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
