A few pics from today ;)
Does anyone know what the module is i have taken a close up of? It is located in the boot in the opposite postion of the factory jack/tools location.
cheers :)
The is the unit that controlls the voltage to the fuel pump in a gtst. Basicly it stops the pump from priming after a few seconds if the motor is not started once the ingnition is turned.
Cheers
Ross
hey dane back to your setup....have you allowed for the remote triggering of the kill switch? I would like to put ours there somewhere as well but am worried about the cable routing to the outside. Needs to be near the base of the windscreen drivers side according to CAMS
We were discussing it before we decided on mounting it where it is, as it was originally going to go in centre console in front of the shifter but we were forced to move it somewhere else due to gearbox position. I think it should still be doable running it down the transmission tunnel, but we'll find out soon enough... hopefully it'll be fine!
Duncan, have you seen the latest batch of electronic kills? Was reading about them on the weekend and they are obviosuly more expensive but far easier to install and far more reliable then the cable type. They are also now cheaper then they used to be
Duncan,
it can be done with cables mounted next to the window on the drivers side, you will need a long drill bit but it takes it directly into the main cabin under the dash. I can send pic of my old slugger when i get back to dubai if you like. I then just ran the cable to the battery box located where the pasneger seat used to be so i can turn the isolator with my hand rather than two cables. Also works for the fire system too.
yeah chris that's where we've always put ours in the past, its like nissan wanted us to put them there lol. But it kind of restricts you in where you can put the kill switch.
in the production car the kill switch activates a NO relay right next to the battery, the standard fuseable link plugs into it. It works fine but if you forget to kill the switch the relay drains the battery.
so in the new car I would like to put the kill switch on the tunnel and cut the actual main power feed - but I'm still worried about the cable pull.
Roy - I've never had any trouble with the mechanical switch an electrical one sounds worse not better to me. I have seen people have the switch key wear out, I should carry a spare one around like Neil does.
Any more pics of your boot lid? :blush:
Is it all c/f or is it fibreglass with a c/f layer?
it weighs 3.5kg and is fiberglass with carbon fiber top layer
boot lid and boot lid mate, flat on top and flat down the back.... if u really need photos go to www.clubhighrollers.com and search GOT04
stay safe
pretty sure bolt in cages are still legal, aslong as you get a cams approved one. From what i've read, the japanise cages run smaller diamiter piping, but run thicker walls.
Yep, I have a CAMS approved bolt in. It's just the jap cages that won't pass
in particular the bends around the dash take all the strength out of the front arms of the jap cages. and like Ben said the diameter on them is too small for cams rules too.
no wonder they are cheap to buy second hand....you can be knocked back by event scruitineers for a non-complying cage, even if no cage is required for that event.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
