hahah taking the high line thru the corner eh?
I guess the wheel alignment was not 100% after that. Glad your dad was ok though.
Surprisinly the alignment was fine, did slice a tyre open though.
i went for a run the r35 v8sc safety car on sunday prior to the start of racing, was pretty cool, but seriously how many flashing lights does one car need!
yeah those lights are a bit of overkill - you're not likely to miss a 35 in a field full of taxis :P
sounds like the targa cars were well received?
didn't touch the wall thankfully.
Kel: everyone loved the targa cars, we had heaps of people come up to us in the pits and say we were the best support catigory. some people came just to watch the targa class.
Edited by sav man
That's really good to hear Ben (on both counts!)
Congrats to Stu and the team on another great initiative for Targa.
sorry for the crap phone pics, but theres been some progress on the evo again finally!
looks pretty cool sitting low on the new coilovers i think.
just waiting on some new caliper pistons and seals, the front seats and we should be right to play (with a windscreen)... special thanks to monty my dog for all his help and downing my boost chocie bar on the sly!
I got there about 8:30am on saturday morning and the R35, a GTP and the Cayenne Medical car were doing laps, man the 35 was impressive!!! GTP was nothing special (had 5 people in the car) but the Cayenne OMG! braking deep into the hairpin and by christ it was fast out!
Yeh definately most enjoyable class!!!
Bloody hell Benny, that 33 has been copping a pizzling lately! Might be time to retire her to Speedway racing I reckon :D
Funnily enough his uncle races speedway!
My vet tells me that chocolate is cumulative in doggies (much like mercury is cumulative in humans)... They can't process it and get rid of it and it can be harmful if enough choco goodies are ingested.
That's why they have carob drops, and not chocolate drops for doggahs!
Just an FYI :D
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
