Hi,
PICS: http://www.thegodzilla.com/car-parts-for-sale.php (scroll down)
Item: RB26 Sump/front dif, complete with Tomei baffel kit.
Description: good condition, comes with Tomei sump baffel kit installed.
Price: $520
Item: New RB26DETT Head Gasket
Description: Brand new Nissan head gasket to suit RB26 motor
Price: $50
Item: R32 GTR Standard front pipe
Description: Standard item, few scratches.
Price: $50 $20
Item: Highmount manifold for RB26
Description: Cost $1200 new... Still basically new like everything else. The wastegate flange has now been cut off so you can have one welded on to suit your wastegate.
Price: only $770
Item: Custom intake for single turbo Rb26
Description: Looks great. Made at Godzilla Motorsport. Comes with silicon hose and clip, ready to instal.
Price: only $170
Item: RB26 Big end bearings - Brand new.
Description: New, in box. Cost $85.15 new
Price: $60
Item: RB26 Main bearings - Brand new.
Description: New, in box. Cost $173.80 new
Price: $135
Item: Exedy Clutch
Description: From my R32 GTR. I had this clutch installed before it went on the dyno. So has done basically no kms.
Price: $700
Item: Revolution Billet Flywheel
Description: I go tthis at the same time as the clutch.
Price: $170
Item: 82ERK Number plates - BZERK
Description: Never fittd to a car, Never registered. Navy blue writing on a silver plate.
Price: $900
Item: HKS Pod filters
Description: Nothing wrong with them at all
Price: $110
Item: RB26 Alternator
Description: RB26 Alternator in good condition
Price: $100
Item: RB26 Water pump
Description: Bought it for rebuild, used only for short time on dyno
Price: $100
NEG on some items
pickup can be made from bulimba or bracken ridge.
parts can be sent Australia wide.
regards,
Drew
https://www.sau.com.au/forums/topic/177175-gtr-parts-aftermarket/
pics of everyting here: http://www.thegodzilla.com/car-parts-for-sale.php"" target="_blank">http://www.thegodzilla.com/car-parts-for-sale.php
i am neg on most prices.. just not the brand new stuff like bearings, head gasket...
I'm interested in the manifold.. a few q's
who made it? chinese? japanese? australian? brand name?
what material is is made from?
is it just the wastegate flange that been cut off or the pipe?
Is the face of the flange still flat id you put a ruler acress it?
to suit T4 single entry pattern?
Cheers,
Mick
Cheers,
Mick
hi, im not sure of the manerial.
this cost me $1200 from hi octane
I have cut about 3cm of the pipe, plenty of room to weld a new flange.
the cut needs to be grinded flat.
this was to suit a gt3540.. not sure if thats T4 or not.
  • 4 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
