Hehe .. I thought this is funny! I was having a late lunch at Northbridge yesterday, when I walked past this beautiful brand new dark blue 350Z with a riced-up GT wing parking outside Gelare !! I thought to myself, this is blasphemy :whatsthat How can someone stick a really high GT wing on this car .. On closer inspection I noticed that the GT wing is the same as the one on my Supra (Top Secret GT2 carbon fibre) . Anyway, as I walked past the front of the car I noticed it had a P-PLATE AND A YELLOW STICKER. Poor kid must have had the “defect sticker” due to the GT wing. :Paranoid:
Conclusion : Black GT wing on a blue 350Z doesn't look right :)
http://www.titanmotorsports.com/topsecgt2car.html
https://www.sau.com.au/forums/topic/17719-yellow-sticker-new-350z-with-gt-wing/
  • Replies 66
haha yeah Paul and I saw the same 350Z pulled over outside of Bunbury - he was travelling with a white R33 also with a GT wing and they also pulled paul over for his GT wing - so there was 3 of us all in a row pulled over for the wings. But i assumed because of Pauls explanation of the fact they are legal that they let him go - so they mustve yellow stickered him somewhere else.
Im sorry i have to disagree with u - on the 350Z the GT wing looks horny as!! but i cant say i like them on the R33's!
Niz, don't get me wrong. I actually like the GT2 wing.. Heck, I like it A LOT. But for some reason, because of the curve nature of the 350Z, sticking a GT wing on a curved surface doesn't look right. I suppose this is why he attracted the attention from the police.
This is on my Supra, but I think the one I saw yesterday was about 50% higher than mine :) .. Beauty is indeed in the eye of the beholder :)
i saw it in the city friday arvo
metallic blue with plates '--999999' somethin like that
that gt wing looks alright suprisingly, much better than they do on r33s etc
had similar look as the top secret 350z in hpi mag...
Quote
GT wings look wrong on all cars.........
There the epitmany of RICE
Daniel
__________________________________________________
As opposed to a Yellow WRX then...
Did any one here about that Orange 350Z the Cops clocked at 242KM/h odd down the kwinana a few weeks back?
Apperently the Commodore couldn't keep up.. And it's got a bigger motor ;-D
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
