r32 rb25de head on the existing rb25 block and transfer all the existing rb20 stuff over to the new head, injectors, manifolds, ignition system etc. except use the rb25 turbo you talking about having.
rb25de head: ~$1000
GT-R valve springs: ~$100
Head Gasket: ~$500
That's assuming the rb25 bottom end is ok
https://www.sau.com.au/forums/topic/177193-dilemma/page/2/#findComment-3240632
  • Replies 64
How much did you pay for it? $2000?
You get what you pay for buddy, I hope you disclose all this when you go to on-sell the car to some poor unsuspecting person.
Nope.. because the job will be done properly this time.. :banana:
With proper parts.. and tools.. So there is no need to hide it.. the will be done right this time..
https://www.sau.com.au/forums/topic/177193-dilemma/page/2/#findComment-3241686
Weetbix...........absolutely no taste............Cocoa Pops or Froot Loops at least.
Some shops get customers that bring in a wheelbarrow full of bits and peices and say 'Build me a car!'.
The shop says 'No way', so the moron wheels his barrow to the next shop, eventually someone will say OK.
To be fair, it happens with mod parts as well, some shops will sell you anything, other shops try to tell you what will work and what is a waste of $$$$.
https://www.sau.com.au/forums/topic/177193-dilemma/page/2/#findComment-3242403
This was taken out from cylinder 1
The diameter of the pison is 85.95mm
The diameter of the bore is 86.05mm (standard bore is 86.0 - somone has been playing with toys they shouldnt of been!)
On the face of the piston is has imprinted "STD" and a big "1" in the middle. Mean anything?
the question I have is..
are these forgies?
What brand?
Edited by GTS4WD
https://www.sau.com.au/forums/topic/177193-dilemma/page/2/#findComment-3242735
Id say, go and get the bores taken out .5mm over standard. Pretty sure every piston manufacturer has that oversize eg. ACL, Aries, HKS, CP, JE etc etc
Prices are average around 1200-1400 bucks for pistons and rings.
Rebore would be around $300ish
Getting Pistons fitted to Rods - Around $200
Hope you find this useful
Andrew
https://www.sau.com.au/forums/topic/177193-dilemma/page/2/#findComment-3243061
Andrew
Yeah mate.. all bits help.. :)
Can anoyone confrim they are forgies though?
https://www.sau.com.au/forums/topic/177193-dilemma/page/2/#findComment-3244478
are these forgies?
What brand?
It's 0.1mm difference! - you have to have some clearance between the piston and bore. The spec for bore is nominal - there will be some manufacturing variations.
https://www.sau.com.au/forums/topic/177193-dilemma/page/2/#findComment-3244638
True.. of MAX .05 (according to the workshop manual)
So the pistons would of been fine if they didnt f*ck around with the bore :) Dodgy deadshits!
https://www.sau.com.au/forums/topic/177193-dilemma/page/2/#findComment-3244675
are these forgies?
What brand?
there defiantly forgies. The piston you have are sold by precision performance. they retail for $1500. they are some chinese brand but dont be to worried there no to bad really. these are mine that we put in rb30's for a cheaper optioned rebuild. Just put it all back together and drive it, as lond as there not damaged it will be sweet. cheers
https://www.sau.com.au/forums/topic/177193-dilemma/page/2/#findComment-3244691
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
