there defiantly forgies. The piston you have are sold by precision performance. they retail for $1500. they are some chinese brand but dont be to worried there no to bad really. these are mine that we put in rb30's for a cheaper optioned rebuild. Just put it all back together and drive it, as lond as there not damaged it will be sweet. cheers
mate.. you are a legend! :)
I owe you a beer!
:D
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3244710
  • Replies 64
Those pistons are Hypatec liquid forged. They are a semi forged piston and are hypereutectic. They are sold by Precision International, they are not a bad piston though I haven't used them in any turbo engine.
More info here: http://www.precisionintl.com/HTML/product/...hypatec_lf.html
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3246111
my advice is now that you know what brand the pistons are, contact the piston manufacturer and ask them wat PTB clearance they reccomend. it may in fact be 0.1mm (unlikely, but possible).
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3247161
**UPDATE**
I WAS looking for a piston to bore clearance of .035 - .05mm (as per Manufacturers requirements)
Called up some blokes down at Silverwater and .1mm seems too big..
So..
plan of attack..
Piston size of 85.95mm WILL fit a stock RB25DET bore and have a gap of .05mm (recommended gap) - Anyone interesed in a cheap set of forgies that will fit stock Rb25DET bore?
BUT
Because the mechanics at deadshit's mechanics R US bored the block out by .05mm (and hence increased the clearance to .1mm and therefore too big) the block and piston combination will not work.. - anyone looking at a cheap 25det block?
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3248658
I doubt it has been bored out 1 thou, 2 thou piston clearnace cant be right for the forgies, its just too small, they would sieze. 4 thou is only a little loose, why not just chuck it back together, it wouldnt have been causing the massive dramas that the car has.
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3249566
GTS4WD,
Try not to over complicate things.
Send the block in to be bored/honed WITH the set of pistons. The machinist will measure up the pistons and bore to suite your intended application. Obviously have a little discussion with regards to what the piston manufacturer recommends, intended use etc etc.
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3249624
GTS4WD,
Well im looking to put together a hi comp 25/30 NA project together.. so.. dont have much use for this..
But I may get the block sleeved and sell the whole bottom end off with the pistons..
Ill get a few quotes for getting it sleeved.. but I mean.. I seen a fair few 25DeT blocks going HEAPS cheap lately.. so Im not sure if its worth it.. but I will get back with you guys about it..
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3249785
Those pistons will run .05mm or so clearance. They are not your usual forged piston which is forged from a billet, they are more along the lines of pressure cast. Being hypereutectic, the coefficient of thermal expansion is a lot lower than a piston forged from a lower silicone content alloy, so not so much difference in size from cold to hot. It would be a lot cheaper to buy a set of pistons than to have the block sleeved.
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3250068
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
