there defiantly forgies. The piston you have are sold by precision performance. they retail for $1500. they are some chinese brand but dont be to worried there no to bad really. these are mine that we put in rb30's for a cheaper optioned rebuild. Just put it all back together and drive it, as lond as there not damaged it will be sweet. cheers
mate.. you are a legend! :)
I owe you a beer!
:D
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3244710
  • Replies 64
Those pistons are Hypatec liquid forged. They are a semi forged piston and are hypereutectic. They are sold by Precision International, they are not a bad piston though I haven't used them in any turbo engine.
More info here: http://www.precisionintl.com/HTML/product/...hypatec_lf.html
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3246111
my advice is now that you know what brand the pistons are, contact the piston manufacturer and ask them wat PTB clearance they reccomend. it may in fact be 0.1mm (unlikely, but possible).
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3247161
**UPDATE**
I WAS looking for a piston to bore clearance of .035 - .05mm (as per Manufacturers requirements)
Called up some blokes down at Silverwater and .1mm seems too big..
So..
plan of attack..
Piston size of 85.95mm WILL fit a stock RB25DET bore and have a gap of .05mm (recommended gap) - Anyone interesed in a cheap set of forgies that will fit stock Rb25DET bore?
BUT
Because the mechanics at deadshit's mechanics R US bored the block out by .05mm (and hence increased the clearance to .1mm and therefore too big) the block and piston combination will not work.. - anyone looking at a cheap 25det block?
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3248658
I doubt it has been bored out 1 thou, 2 thou piston clearnace cant be right for the forgies, its just too small, they would sieze. 4 thou is only a little loose, why not just chuck it back together, it wouldnt have been causing the massive dramas that the car has.
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3249566
GTS4WD,
Try not to over complicate things.
Send the block in to be bored/honed WITH the set of pistons. The machinist will measure up the pistons and bore to suite your intended application. Obviously have a little discussion with regards to what the piston manufacturer recommends, intended use etc etc.
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3249624
GTS4WD,
Well im looking to put together a hi comp 25/30 NA project together.. so.. dont have much use for this..
But I may get the block sleeved and sell the whole bottom end off with the pistons..
Ill get a few quotes for getting it sleeved.. but I mean.. I seen a fair few 25DeT blocks going HEAPS cheap lately.. so Im not sure if its worth it.. but I will get back with you guys about it..
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3249785
Those pistons will run .05mm or so clearance. They are not your usual forged piston which is forged from a billet, they are more along the lines of pressure cast. Being hypereutectic, the coefficient of thermal expansion is a lot lower than a piston forged from a lower silicone content alloy, so not so much difference in size from cold to hot. It would be a lot cheaper to buy a set of pistons than to have the block sleeved.
https://www.sau.com.au/forums/topic/177193-dilemma/page/3/#findComment-3250068
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
