been using the ORC carbon twin now for a few months and it is the best clutch i have used fullstop, as far as warming up and so forth.... dont believe the hype. If your going to do a 1/4 mile run straight off the trailer then it may be an issue (same with any clutch) but our car with well over 300rwkw is easy enough to drive up on a car trailer from dead cold and ready to drift by the time you drive from the pits to the form up area. We even did a full power run (warmed engine but did not use clutch) on the dyno to test the myth and there was no slippage noticeable.
