Currently I have some 2way 6" front and rear with 12" sub.
The rear left doesnt seem to work (I think it's due to a wiring problem somewhere)
Anyways was contemplating removing the rear speakers or not even connecting them.
What's everyone else think?
Also think I might change the fronts to splits, the Jaycar ones coz I hardly get any treble facing towards me. Thoughts?
Currently using Jaycar 4x100W AMP, a SONY Sub w/ box (which I got for $50 ~2yrs ago from a dude who used it only at his house)
https://www.sau.com.au/forums/topic/177219-speakers/
Good idea.
Rears don't really do much apart from providing 'fill' for passengers in the back seat.
If you're looking for a fairly low-budget upgrade for the front, the Jaycar Precision Response splits are v.good value for money @ $149 RRP (link).
If you are looking for product suggestions though Victor, use the 'what to buy' thread above. Cheers! :D
https://www.sau.com.au/forums/topic/177219-speakers/#findComment-3238079
I would rather go a sub in boot + amped splits up front over 6x9s in the car. Some ppl will want 6x9s. Personal preference really.
In my old GTST, the rears were ripped out at compliance. Fronts were amped. In my GTR, the rears are in, run off the deck and the fronts amped. Honestly I can't notice the difference having the rear speakers in. Then again, I don't have any back seat passengers in the car.
Unplug your rear speakers, and drive around for a week. See if there's a noticeable difference. I reckon there won't be much.
https://www.sau.com.au/forums/topic/177219-speakers/#findComment-3238150
there would be a big difference. i guess how notable this is depends on what speakers you have. ive got 6" 'something' speakers upfront and 6x9 infinitys in rear with 12" pheonix gold sub. fronts and 6x9's running off my pioneer 6850 deck which you can adjust almost everything i guess! just do this instead (it'll be easier) on your headunit, not sure if it was fade or balance, but turn the thing all the way to FRONT ONLY. is there a sound difference? now turn it back to zero or watever it was on before. you should notice a difference, but HOW different all depends on the quality of speakers.
https://www.sau.com.au/forums/topic/177219-speakers/#findComment-3239868
Yo Vic,
I dont mind my rear speakers, ive got 6x9s in there just coz i got them for free as you know... i find that even though your ears face forward and what not, the rear speakers kinda "Fill" the car with sound.....
Next time im over have a listen, i think anything in the back is better than nothing, just to create some noise from that general direction...
https://www.sau.com.au/forums/topic/177219-speakers/#findComment-3242974
i reckon, get some component speakers for the front, 2-way won't really cut it :S
get rid of the rears, put the 2 channels of the amp into the fronts, then bridge the other channel into the sub :P put grilles over the speaker holes left by the gap of the rear speakers and let the bass from the sub flow through :)
https://www.sau.com.au/forums/topic/177219-speakers/#findComment-3250839
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
