Froze my balls off at WSID last night!
Did 3 runs, best I got was [email protected]/H
Car is 350GT Sedan with CVT gearbox.
Only a ztube and air filter for mods.
I did 2 runs in manual-mode and 1 in the auto. VDC was off on all. The auto mode was a little slower, but the slip light kept coming on until half way through that run? Can't have been slipping that much could it?
I pretty much nailed the launch all 3 times, but the track was freezing cold and I had some major slippage through 1st gear. Best I could do with stock tires.
Slips are coming.
A little disappointed not being able to crack 14's but I know this car is made for cruising instead.
What are you you guys getting? Please list mods and gearbox type!
Edited by -= SKiZO =-
https://www.sau.com.au/forums/topic/177220-took-the-car-to-wsid-last-night/
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
